Error : "Error: Error opening SQLite3 database: unable to open database file"
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
reza
Domoticz version: 2024.4
Post by reza »
hi guys
version 2024.4
raspberry pi 4
some times when i unplug/plug power supply of raspberry , domoticz go to offline , when i want run this manually with this command "./domoticz" i have this error :
Of course, I have made a change in Raspberry. After all the settings in domoticz, I put my sd card in read-only mode. Could it be because of this or is the problem from somewhere else?
willemd
Domoticz version: 2024.1
Re: Error : "Error: Error opening SQLite3 database: unable to open database file"
Post by willemd »
reza wrote: Monday 02 September 2024 13:18 hi guys
version 2024.4
raspberry pi 4
I don't think "./domoticz" is the way to start domoticz.
Try "sudo service domoticz start"
(not sure of the sudo is needed)
reza
Post by reza »
[/quote]
[/quote]
my domoticz is in startup and always auto start. but some time with unplug/plug or reboot can not auto start and i check with ./domoticz for see errors. i see i have this error . after several reboot or several unplug/plug again auto startup domoticz and worked. but this is not true and Annoying
Domoticz version: 2025.1
version 2024.4
raspberry pi 4
If your Domoticz database is also on that read-only sd card than this probably is the reason your Domoticz will not work....
reza
Post by reza »
waltervl wrote: Monday 02 September 2024 20:29
[/quote]
I do read-only for protect sd card (stop crash SD)
so are there any solution for protect sd card?
The database needs to be updated somehow on a disk. So you need a writable disk. You could invest in adding an SSD to your Pi. Or use an high quality SD
