restart domoticz possible by esp32?
Posted: Friday 23 August 2024 21:49
by BartSr
Due to current problem that domoticz requires a restart few times each week I wonder if it's possible to sent kind of HTTP command from esp.
Is that doable. I am looking for command something like:
http:// domoticzIP, 'sudo service domoticz.sh restart'
or do I suggest something complete idiot?
Bart
Re: restart domoticz possible by esp32?
Posted: Friday 23 August 2024 22:26
by WouterO
You could easily make a crontab job, e.g., restarting Domoticz every day, including the command sudo systemctl restart domoticz.service
The underlying problem, though, in my opinion is something in your Domoticz setup. As far as I know there is no ‘current problem’ with Domoticz requiring a restart. At least, I am not experiencing anything wrong with the newest Domoticz version, 2024.7.
Posted: Friday 23 August 2024 23:44
by BartSr
@Wouter0
A number of members als suffer from same problem. Also a github issue is there. Gizmocus has a look at it too.
I don't want a crontab solution for I want to restart once domoticz don't response.
Posted: Saturday 24 August 2024 6:10
by Egregius
Use the developer tools of your browser...
http://192.168.2.2:8080/json.htm?type=command&param=system_reboot
This is a script I run on the domoticz server itself:
DOMOTICZ=`curl -s --connect-timeout 2 --max-time 5 "http://127.0.0.1:8080/json.htm?type=command&param=getdevices&rid=1"`
STATUS=`echo $DOMOTICZ | jq -r '.status'`
if [ $STATUS = "OK" ] ; then
	exit
	sleep 20
	STATUS2=`echo $DOMOTICZ | jq -r '.status'`
	if [ $STATUS2 = "OK" ] ; then
		exit
		sleep 20
		STATUS3=`echo $DOMOTICZ | jq -r '.status'`
		if [ $STATUS3 = "OK" ] ; then
			exit
			/usr/sbin/service domoticz stop
			/usr/sbin/service domoticz start
		fi
	fi
fi
Posted: Saturday 24 August 2024 18:40
by WouterO
BartSr wrote: Friday 23 August 2024 23:44 @Wouter0
Yeah, I just saw the other messages. I agree that for your problem a crontab job is no solution. I hope the cause of your problem (some plug-in issue?) is soon found.
Posted: Saturday 24 August 2024 21:58
by waltervl
As long as your crashing issue is not fixed use the monit application to monitor Domoticz and have it restarted when Domoticz becomes unresponsive. See wiki for more information https://www.domoticz.com/wiki/Monitoring_domoticz
