Due to current problem that domoticz requires a restart few times each week I wonder if it's possible to sent kind of HTTP command from esp.
Is that doable. I am looking for command something like:
http:// domoticzIP, 'sudo service domoticz.sh restart'
or do I suggest something complete idiot?
Bart
restart domoticz possible by esp32?
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Re: restart domoticz possible by esp32?
You could easily make a crontab job, e.g., restarting Domoticz every day, including the command sudo systemctl restart domoticz.service
The underlying problem, though, in my opinion is something in your Domoticz setup. As far as I know there is no ‘current problem’ with Domoticz requiring a restart. At least, I am not experiencing anything wrong with the newest Domoticz version, 2024.7.
@Wouter0
A number of members als suffer from same problem. Also a github issue is there. Gizmocus has a look at it too.
I don't want a crontab solution for I want to restart once domoticz don't response.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- Egregius
- Domoticz version: v2024.7
Use the developer tools of your browser...
This is a script I run on the domoticz server itself:
http://192.168.2.2:8080/json.htm?type=command¶m=system_reboot
DOMOTICZ=`curl -s --connect-timeout 2 --max-time 5 "http://127.0.0.1:8080/json.htm?type=command¶m=getdevices&rid=1"`
STATUS=`echo $DOMOTICZ | jq -r '.status'`
if [ $STATUS = "OK" ] ; then
exit
sleep 20
STATUS2=`echo $DOMOTICZ | jq -r '.status'`
if [ $STATUS2 = "OK" ] ; then
exit
sleep 20
STATUS3=`echo $DOMOTICZ | jq -r '.status'`
if [ $STATUS3 = "OK" ] ; then
exit
/usr/sbin/service domoticz stop
/usr/sbin/service domoticz start
fi
fi
fi
Yeah, I just saw the other messages. I agree that for your problem a crontab job is no solution. I hope the cause of your problem (some plug-in issue?) is soon found.
- Domoticz version: 2024.7
As long as your crashing issue is not fixed use the monit application to monitor Domoticz and have it restarted when Domoticz becomes unresponsive. See wiki for more information https://www.domoticz.com/wiki/Monitoring_domoticz
