Could not find device in system Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
capman
Post by capman »
I have some time a error in my log. But i can't find the problem.
I found no idx 0 in my app. Also looking in my events but found also nothing
with idx 0 in it. Somebody know how to fix this (database maybe) ?
Thanks.
Error: EventSystem: Could not find device in system: (idx 0)
Domoticz version: 2024.7
Re: Could not find device in system
Check for double names (same name for multiple devices). The name for each device should be unique.
capman
Post by capman »
Change some duplicated names. No luck :(
A lot of 'unknown' devices. These have all the same name ;)
Thanks 4 the reply.
screenshot of error
Schermafbeelding 2024-07-02 125042.jpg (202.42 KiB) Viewed 2158 times
gizmocuz
Post by gizmocuz »
Searching in the domoticz code, you find this line here:
CEventSystem::ProcessDevice
Are you using one of the below hardware/plugins:
- Kodi
- Logitech Media Server
- Panasonic TV
Did you update domoticz to the latest beta version and reverted to a previous version?
capman
Post by capman »
Yes , a use Kodi and LMS hardware.
Should a remove them and then add them again ? Or ...
It's possible that a did in the past a reverse update 8-)
gizmocuz
Post by gizmocuz »
Is it possible to disable these two hardware types and see if the error disappears?
capman
Post by capman »
When a disable kodi and LMS hardware the error stops :o .
Enable kodi > no error in log.
Enable LMS > the error is back.
Should a reinstall LMS hardware ?
Thanks.
gizmocuz
Post by gizmocuz »
I have no idea as I don't use this hardware. You at least found out where the problem is appearing from.
How about you select this hardware, disable it, press update
Give it another name, enable it, and press ADD, you just made a copy
Do you see the same errors with the copy?
capman
Post by capman »
That's it !! Just like you say :o
Finally , no more errors , thanks a lot :D
Just one question , how do you know to search in that direction ?
gizmocuz
Post by gizmocuz »
I downloaded the domoticz source code and searched for the error message.
This pointed me to the hardware that creates the error message.
capman
Post by capman »
Good 2 know 4 future errors :lol:
This topic can b marked as solved.
