Script modification for switching devices by rain
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
I need a bit of help to modify this script which i've found here : https://domoticaboard.nl/index.php?topic=44.0
The script is running, but i like to trigger more devices then the one now
How can i add a list of devices that will be switch by the script
So far i know you can do it with the funcrion "pairs"
-- Define all the sensors which needs to be considered for the sunscreen to close
local sensors = {
    rain = {
        active = true,
        device = 'RegenData',
        closeRule = function(device)
            return device.rainRate > 0
local sunscreenDevice   = 'TestSwitch'      -- Define the name of your sunscreen device
local dryRun            = false             -- Enable dry run mode to test the sunscreen script without actually activating the sunscreen
    active = true,
        --timer = {'every minute'},
        devices = {290},
    logging = {
        level = domoticz.LOG_DEBUG,
        marker = 'Sunscreen'
    execute = function(domoticz)
        local function switchOn(sunscreen)
            if (sunscreen.state == 'Off') then
                if (not dryRun) then
                sunscreen.switchOn()
                --domoticz.notify('Sunscreen', message)
                domoticz.log(message, domoticz.LOG_INFO)
        local function switchOff(sunscreen)
            if (sunscreen.state == 'On') then
                sunscreen.switchOff()
        local sunscreen = domoticz.devices(sunscreenDevice)
        -- Check all sensor tresholds and if any exeeded close sunscreen
        for sensorType, sensor in pairs(sensors) do
            if (sensor['active'] == true) then
                local device = domoticz.devices(sensor['device'])
                local closeRule = sensor['closeRule']
                domoticz.log('Checking sensor: ' .. sensorType, domoticz.LOG_DEBUG)
                if (closeRule(device)) then
                    switchOn(sunscreen, sensorType .. ' treshold exceeded, Sunscreen up')
                    domoticz.log(sensorType .. ' treshold exceeded', domoticz.LOG_DEBUG)
                    -- Return early when we exeed any tresholds
                    return
                domoticz.log('Sensor not active skipping: ' .. sensorType, domoticz.LOG_DEBUG)
Re: Script modification for switching devices by rain
You can also make a Domoticz group or scene, add the devices you want to switch to the group and switch the group by the script.
Else you have to change the switching(sunscreen) function....
madpatrick
Thanks. Maing a group was also the easiest solution i could think of.
It is working !
