It seems my database got removed with updating beta -> beta.
-> 2024.4.16065 -> 2024.4.16071
Not sure what happened.
It is also not present in the last automatic backup made when updating.
Database removed updating beta
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: V12461
- gizmocuz
Re: Database removed updating beta
That is impossible, something else must have happened.
We do not remove databases
Good that you have a backup with 'a' database, but try this
stop domoticz
(sudo service domoticz stop, or stop your docker compsoe)
have a look in the folder, and see if you can see the following files
domoticz.db
domoticz.db-wal
domoticz.db-shm
If you have stopped domoticz, and still see the wal/shm, you can remove these files and restart domoticz
Also have a look at the size of the db file
Else restore the database from one of your backups, but as said, remove the wal/shm files first as they belong to your previous database and this could cause issues you are seeing now
stop domoticz
domoticz.db
domoticz.db-wal
domoticz.db-shm
