Hello, i would like to know if i turn off deconz.service and i start to use the domoticz zigbee plugin, if i have to redo all my devices again, because i did that and there are only 2 devices created some text device and an alert device. But before i go any further, i would like to know if i can keep using my device IDX from when deconz was used, or do i get all new IDX in domoticz when using the plugin?
Hope someone can clear that up for me? Thanks.
deconz to zigbee plugin
- Thuis
I Love Domoticz ! And the community around it :-)
- Target OS: -
Re: deconz to zigbee plugin
Hello, unfortunately you will need to remake lot of things. The 2 plugins will not work same at all, so you will need to restart from scratch, and not possible to "choose" an IDX, the plugin will take the first one available, and will be not the same one used on the old plugin.
- Thuis
ha, ok, thanks for the acknowledgement. Would be too good to be true.Thorgal789 wrote: ↑Saturday 15 June 2024 17:33 Hello, unfortunately you will need to remake lot of things. The 2 plugins will not work same at all, so you will need to restart from scratch, and not possible to "choose" an IDX, the plugin will take the first one available, and will be not the same one used on the old plugin.
