I have some door/window sensors (Aqara,MCCGQ11LM) that function without any problems. Each sensor consists of 6 separate devices (switch, battery percentage, link quality, voltage, temperature and power_outage_count).
Recently I accidentally deleted the switch device from one of the sensors, and don't know how to undelete it?
I tried re-pairing without result. Also removed the sensor complete, re-paired it, but only 5 of the 6 devices came back, but no switch.
My configuration:
RaspberryPi 3b
Domoticz Version: 2024.4
Python Version: 3.7.3
Zigbee plugin: v.3.2.0-beta
Zigbee2mqtt: v.1.36.1 (zStack3x0 20211114)
Zigbee CC2652RB coördinator USB-dongle
How to undelete a accidentally removed Zigbee-device in Domoticz
- Domoticz version: 2024.7
Re: How to undelete a accidentally removed Zigbee-device in Domoticz
Perhaps restart the plugin?
- gizmocuz
Yes, just disable/enable the MQTT-AD hardware and the device should be created again (enabled accept new devices in settings)
Thanks for responding.
I still use the "old" Zigbee plugin v.3.2.0-beta Stas-Demydiuk, but restarting the plug-in (or a complete restart of the raspb pi) had unfortunately no result.
I allready have the newer MQTT Auto Discovery plug installed in my hardware list but not yet activated (I have not yet switched according to the procedure due to the necessary adjustments to the dzvents scripts).
My configuration:
RaspberryPi 3b
Zigbee2mqtt: v.1.38.0 (zStack3x0 20211114)
My configuration:
RaspberryPi 3b
