How to Modify Data in DATA-PUSH HTTP?
andrewcarsten17
Post by andrewcarsten17 »
I want to send data from a power sensor to a website using Data-Push-HTTP. On the command line, it works with the following command:
wget --post-data '{"watt":120}' https://website.de
You can see how I tried it in the attached picture, but it does not work.
  • Is there a way to debug how Domoticz creates the URL to ensure it is correct?download lagu
  • The second problem is that the value %v is a number like 123.12, but the website only accepts 123.
  • Is there a way to manipulate the data before sending it?
In the log, I can only see:
HttpLink: sending global variable Watt with value: -256.00
HttpLink: response Unexpected error occurred.
Thanks for your help.
Sorry about the spaces, but it seems URLs and numbers with dots are not allowed here.
Re: How to Modify Data in DATA-PUSH HTTP?
