New version Z4D Zigbee plugin - CPU usage
WouterO
Post by WouterO »
Hi pipiche,
You know I like your plugin very much. In the newest .12 version you claim a more efficient cpu% usage. I have experienced just the opposite after updating from .11.
It’s no big deal, but I get a significant higher (1.5 times) minimum cpu usage since I installed the newest version. Even after a Domoticz restart and system reboot I got the same increased minimal cpu usage. Again, no big deal, but it’s in contrast with your claim in the Release Notes.
pipiche
Re: New version Z4D Zigbee plugin - CPU usage
Post by pipiche »
This looks strange.
Are you using ZIgate as the coordinator ?
I'm also quiet surprise on the very low % before ? What type of HW are you using ?
WouterO
Post by WouterO »
Hi pipiche, thank your reacting. I use a Raspberry Pi 4 with the Motherboard sensor plugin to monitor the cpu% . I agree with you that the % is quite low. In my opinion, they should be multiplied by 4 for each cpu-core of the RPi. Also, the minimum % is plotted, not the mean %, but the trend is identical. That doesn’t change my observation. Mind you, it’s no criticism, I just want to share my measurement results. Moreover, because you claim a better efficiency.
I use the sonoff plus dongle with the Silicon Labs chip.
Domoticz version: 2025.1
I must say I also see a small increase in average CPU usage (from approx 3.5 to 4.3 %) after updating the plugin from .11 to .12 running on X86 Ubuntu 20.04 LTS
Nothing to worry abouth though, as always still working great!
WouterO
Post by WouterO »
Ah, thanks for repeating my result, now n=2 🙂
And I sure agree with your last line:
‘Nothing to worry about though, as always still working great!‘
