I was hoping that someone might have a general idea of what could be causing this and didn't want to just dump the scripts.
But if anyone is willing to look into what the possible cause could be, I would really appreciate it.
Note: In the meantime I have adjusted the timetables so that they do not both run at the same time
The first script is the t-Earthquake-KNMI script. (meanwhile changed the schedule
-- 07-05-2024 script by Jan Peppink, https://ict.peppink.nl
-- Based on earlier script found on https://www.domoticz.com/forum/viewtopic.php?t=41380
-- Missed Dutch earthquakes. Modified script to get info from KNMI Aardbevingen RSS.
-- Parse XML result to get info from the most recent of 30 in the list.
-- URL = https://cdn.knmi.nl/knmi/map/page/seismologie/GQuake_KNMI_RSS.xml
-- Function 'getUTCtimediffseconds' expected in global_data.
-- 09-05-2024 directly make use of dz.log instead of the 'logthis' function in global_data.
-- 10-05-2024 Again some adjustments to the log function.
-- 13-05-2024 Added font color for hyperlinks.
-- 21-05-2024 Sometimes error on local atUTCtime = description_table[1] .. ' ' .. string.sub( description_table[2], 2, 6 )
-- bad argument #1 to 'sub' (string expected, got nil); However - Manually never seen.
--- Your settings ----------------------------------------------------------------
-- First set the used device index numbers and variables you might want to change.
local alertIdx = 1000 -- Set to the idx of the Virtual Alert sensor you have to create for this script
local mailto = '[email protected]' -- Set E-mail adres to sent notification to.
local knmiURL = 'https://cdn.knmi.nl/knmi/map/page/seismologie/GQuake_KNMI_RSS.xml'
-- Define distance for ALERTLEVEL colors
-- From dClose to the maxRadius we get: ALERTLEVEL_GREY
local dClose = 300 -- From distance dCloser to dClose: ALERTLEVEL_YELLOW
local dCloser = 200 -- From distance dClosest to dCloser: ALERTLEVEL_ORANGE (+ eMail notification)
local dClosest = 100 -- From distance 0 to closest: ALERTLEVEL_RED (+ eMail notification)
timer = {
--'every 2 minutes', -- Only for testing.
'at *:02',
'at *:07',
'at *:12',
'at *:17',
'at *:22',
'at *:27',
'at *:32',
'at *:47',
'at *:52',
'at *:57',
httpResponses = {
'knmi-rss' -- matches callback string below
logging = {
-- Level can be domoticz.LOG_INFO, domoicz.LOG_MODULE_EXEC_INFO, domoticz.LOG_DEBUG, domoticz.LOG_ERROR or domoticz.LOG_FORCE
level = domoticz.LOG_INFO,
--level = domoticz.LOG_DEBUG,
marker = 'KNMI-',
execute = function(dz, triggeredItem)
-- Set Local environment=================
local _u = dz.utils -- Holds subset of handy utilities.
local _h = dz.helpers -- Holds the global functions.
local _d = dz.globalData -- Holds the global data.
-- Set your loccation coordinates from Domoticz settings =================
local yourLatitude = dz.settings.location.latitude
local yourLongitude = dz.settings.location.longitude
-- Use color variable for hyperlink font color
htmlColor = 'Blue'
-- Set your alert device index to store the result.
local alertLevel = dz.ALERTLEVEL_GREY -- Holds the alertLevel (color) to set
local alertText = ''
local lastalertText = dz.devices(alertIdx).text -- Holds string of the previous round.
local lTimediff = 0 -- Calculate diff in seconds between UTC and local time of this event.
local delString = "" -- Holds (sub) string to delete.
-- Local Functions go here =============
-- Calculate distance using Haversine formula
local function calculateDistance(lat1, lon1, lat2, lon2)
local R = 6371 -- Earth radius in kilometers
local dLat = math.rad(lat2 - lat1)
local dLon = math.rad(lon2 - lon1)
local a = math.sin(dLat / 2) * math.sin(dLat / 2) + math.cos(math.rad(lat1)) * math.cos(math.rad(lat2)) * math.sin(dLon / 2) * math.sin(dLon / 2)
local c = 2 * math.atan2(math.sqrt(a), math.sqrt(1 - a))
local distance = R * c
return distance
-- Now start to do something ============
if (triggeredItem.isTimer) then
dz.openURL({
url = knmiURL,
method = 'GET',
callback = 'knmi-rss'
if (triggeredItem.isHTTPResponse) then
-- Process the obtained data.
if (triggeredItem.ok and triggeredItem.isXML) then
-- We have something, which looks like this:
--<rss xmlns:geo="http://www.w3.org/2003/01/geo/wgs84_pos#" xmlns:georss="http://www.georss.org/georss" version="2.0">
-- <channel>
-- <copyright>Copyright KNMI</copyright>
-- <description>KNMI - de laatste 30 registraties van aardbevingen en andere seismo-akoestische bronnen in en rondom Nederland</description>
-- <title>KNMI - de meest recente registraties van aardbevingen en andere seismo-akoestische bronnen in en rondom Nederland</title>
-- <item>
-- <title>2024-05-05, 't Zandt, M=0.3</title>
-- <description>2024-05-05, 19:14:45, Lat = 53.357, Lon = 6.783, Diepte = 3.0 km, M = 0.3, Plaats = 't Zandt, Author = KNMI, Type = Geinduceerd, Analyse = Reviewed</description>
-- <geo:lat>53.357</geo:lat>
-- <geo:lon>6.783</geo:lon>
-- <georss:point>53.357 6.783</georss:point>
-- <link>http://www.knmi.nl/nederland-nu/seismologie/aardbevingen/knmi2024ivvz</link>
-- <guid>knmi2024ivvz</guid>
-- </item>
local result_table = triggeredItem.xml
if type( result_table ) == "table" then
dz.log( 'result_table: type = ' .. type(result_table), dz.LOG_DEBUG )
-- Get only the info from the first item.
-- Get link to page with details.
dz.log( 'URL details = ' .. result_table.rss.channel.item[1].link, dz.LOG_DEBUG )
local qUrl = tostring( triggeredItem.xml.rss.channel.item[1].link )
-- The complete description to split up. Put it in a table.
dz.log( 'Full description string = ' .. result_table.rss.channel.item[1].description, dz.LOG_DEBUG )
local description_table = _u.stringSplit( result_table.rss.channel.item[1].description, ',' )
-- Get time (= UTC time) from the description_table.
-- Record 1 = 2024-05-05; Record 2 = 19:14:45 (strip the seconds)
dz.log( 'String 1 = "' .. description_table[1] .. '" en String 2 = "' .. description_table[2] .. '"', dz.LOG_DEBUG )
atUTCtime = dz.time.dateToDate( atUTCtime, 'yyyy-mm-dd hh:MM', 'dd-mm-yyyy hh:MM', 0 )
dz.log( 'atUTCtime = ' .. atUTCtime, dz.LOG_DEBUG )
-- Calculate the Local time.
local qUnixtime = dz.time.dateToTimestamp( atUTCtime, 'dd-mm-yyyy hh:MM' )
lTimediff = _h.getUTCtimediffseconds( qUnixtime )
local atLocalTime = dz.time.timestampToDate( qUnixtime, 'dd-mm-yyyy hh:MM', lTimediff )
dz.log( 'atLocalTime = ' .. atLocalTime, dz.LOG_DEBUG )
-- Record 3 = Lat = 53.357
delString = "Lat = "
local qLat = tostring(description_table[3]):gsub( delString, "" )
dz.log( 'qLat = ' .. qLat, dz.LOG_DEBUG )
-- Record 4 = Lon = 6.783
delString = "Lon = "
local qLon = tostring(description_table[4]):gsub( delString, "" )
dz.log( 'qLon = ' .. qLon, dz.LOG_DEBUG )
-- Record 5 = Diepte = 3.0 km
delString = "Diepte = "
local qDepth = tostring(description_table[5]):gsub( delString, "" )
dz.log( 'qDepth = ' .. qDepth, dz.LOG_DEBUG )
-- Record 6 = M = 0.3
delString = "M = "
local qMag = tostring( description_table[6]):gsub( delString, "" )
dz.log( 'qMag = ' .. qMag, dz.LOG_DEBUG )
-- Record 7 = Plaats = 't Zandt
delString = "Plaats = "
local qPlace = tostring(description_table[7]):gsub( delString, "" )
dz.log( 'qPlace = ' .. qPlace, dz.LOG_DEBUG )
-- Record 8 = Author = KNMI
local qAuthor = description_table[8]
dz.log( 'qAuthor = ' .. qAuthor, dz.LOG_DEBUG )
-- Record 9 = Type = Geinduceerd
local qType = description_table[9]
dz.log( 'qType = ' .. qType, dz.LOG_DEBUG )
-- Record 10 = Analyse = Reviewed
-- Calculate distance from home location.
local distance = calculateDistance( yourLatitude, yourLongitude, qLat, qLon )
-- Round the distance to the nearest kilometer
local roundedDistance = _u.round( distance, 0 )
--Set Alertlevel color based on distance.
if roundedDistance < dClosest then
alertLevel = dz.ALERTLEVEL_RED
elseif roundedDistance >= dClosest and roundedDistance < dCloser then
alertLevel = dz.ALERTLEVEL_ORANGE
elseif roundedDistance >= dCloser and roundedDistance < dClose then
alertLevel = dz.ALERTLEVEL_YELLOW
--Set and format the new alertText
local alertText = tostring( atLocalTime .. ' uur in ' .. qPlace .. '\n' .. 'Magnitude: ' .. qMag .. '. Diepte: ' .. qDepth .. '. Afstand: ' .. roundedDistance ..' km.\n' .. '<a href="https://maps.google.com/?q=' .. qLat .. ',' .. qLon .. '" target="_blank"><span style="color: ' .. htmlColor .. '">Toon locatie</span></a>' .. ' - ' .. '<a href="' .. qUrl .. '" target="_blank"><span style="color: ' .. htmlColor .. '">Toon bron</span></a>' )
dz.log( 'LastalertText = ' .. lastalertText, dz.LOG_DEBUG )
dz.log( 'NewalertText = ' .. alertText, dz.LOG_DEBUG )
-- Only update and send mail when info has changed. and
if alertText ~= lastalertText then
-- We have new information, so update the device.
dz.devices(alertIdx).updateAlertSensor( alertLevel, alertText )
-- Only send email when it comes closer then dCloser
if roundedDistance <= dCloser then
--Set and format the new mail message
local message = tostring('Plaats: ' .. qPlace .. '<br>' ..
'Magnitude: ' .. qMag .. '<br>' ..
'Diepte: ' .. qDepth .. '.<br>' ..
'Lokale Tijd: ' .. atLocalTime .. ' uur.<br>' ..
'UTC Tijd: ' .. atUTCtime .. ' uur.<br>' ..
'Afstand: ' .. roundedDistance .. 'km.<br>' ..
'Coördinaten: ' .. qLat .. ','.. qLon .. '<br>' ..
qAuthor .. '<br>' ..
qType .. '<br>' ..
'<a href="https://maps.google.com/?q=' .. qLat .. ',' .. qLon .. '">Toon locatie</a>' .. '<br>' ..
'<a href="' .. qUrl .. '">Toon bron</a>' .. '<br>' )
-- Send the mail
dz.email( 'Aardbeving ' .. qPlace, message, mailto )
dz.log( 'No result_table found', dz.LOG_ERROR )
dz.log( 'Item or XML - NOT OK', dz.LOG_ERROR )
-- That's All --------------------------------------------------
The second script is the t-Alarmeringen script.
-- 03-12-2022 script by Jan Peppink, https://ict.peppink.nl
-- Creates a custom html page with x lines of the last alarm notifications for the city.
-- icon images are expected to be placed. See Your settings.
local maxLines = 10 -- Max number of lines to show in the table.
local locationToSearch = 'MyStreet' -- Get a notification when streetname is found.
local al_emailTo = '[email protected]' -- Set E-mail adres to sent notification to.
local cityName = 'Alphen Aan Den Rijn' -- Used in header, and used to strip from text.
-- Use the same spelling that is found in description.
--Set the Fullpath to the html file. Example '/home/username/domoticz/www/templates/Alarmeringen.html'
local htmlFile = '/home/username/domoticz/www/templates/Alarmeringen.html'
--Set imageDir, where the icon_ambulance.web, icon_brandweer.webp, icon_politie.webp images are expected
local imageDir = '/templates/images' -- starting from root
--Set the URL to get the rss for your city. Find city name at: https://alarmeringen.nl/plaatsen.html
-- Example region = 'http://alarmeringen.nl/feeds/region/hollands-midden.rss'
-- Example city = 'https://alarmeringen.nl/feeds/city/alphen-aan-den-rijn.rss'
local alarmeringURL = 'https://alarmeringen.nl/feeds/city/alphen-aan-den-rijn.rss'
timer = {
'at *:01',
'at *:06',
'at *:11',
'at *:16',
'at *:21',
'at *:26',
'at *:31',
'at *:46',
'at *:51',
'at *:56',
httpResponses = {
'alarmering' -- must match with the callback passed to the openURL command
logging = {
marker = 'Alarmering-',
execute = function( dz, triggeredItem )
local _u = dz.utils
local locationFound = false
dz.openURL({
url = alarmeringURL,
method = 'GET',
callback = 'alarmering', -- see httpResponses above.
-- Results are in:
-- triggeredItem.xml.rss.channel.description -Alarmeringen.nl: Alle alarmeringen voor: Hollands Midden
-- triggeredItem.xml.rss.channel.item
-- triggeredItem.xml.rss.channel.item.title -a1 coornhertdreef leiddp : 16161
-- triggeredItem.xml.rss.channel.item.description -Ambulance met spoed naar Coornhertdreef in Leiderdorp
-- triggeredItem.xml.rss.channel.item.pubDate -Fri, 09 Dec 2022 08:20:16 +0000
-- utcTimeDiffSeconds to calculate local time from resulting pupDate
local utcTimeDiffSeconds = _h.getUTCtimediffseconds( dz.time.dDate )
dz.log( 'utcTimeDiffSeconds = ' .. utcTimeDiffSeconds, dz.LOG_DEBUG )
local result_table = triggeredItem.xml.rss.channel.item
dz.log( 'Existing result_table: type = ' .. type( result_table ), dz.LOG_DEBUG )
-- Witing the custom HTML file ----------------
--Step 1. Remove old file and Open file for appending
dz.log( 'html file = ' .. htmlFile, dz.LOG_DEBUG )
if _u.fileExists( htmlFile) then os.remove( htmlFile ) end
local file = io.open( htmlFile, "a" )
--Step 2. Write fileHeader ----------------
local fileHeader = '<!DOCTYPE html>\n' ..
'<html>\n' ..
' <head>\n' ..
' <title>Laatste ' .. maxLines .. ' Alarmeringen.nl meldingen</title>\n' ..
' </head>\n' ..
' <body bgcolor="black">\n' ..
' <h1 style="text-align:center; color: white;">Alarmeringen.nl voor ' .. cityName .. ' </h1>\n' ..
'<p></p>' ..
' <table border="1" style="border-collapse:collapse; margin-left:auto; margin-right:auto; color: yellow;" bgcolor="black"\n' ..
' <tr>\n' ..
' <th align="left" style="padding: 3px 10px 3px 10px; color: cyan;">Tijd</th>\n' ..
' <th colspan="2" align="left" style="padding: 3px 10px 3px 10px; color: cyan;">Laatste ' .. maxLines .. ' meldingen</th>\n' ..
' </tr>\n'
file:write( fileHeader )
--Step 3. Get and write tableContent in loop ----------------
local tc = #result_table
local counter = 0
local tableContent = ''
for i = 1, tc do
--Interesting fields - example:
--title: a2 pieter floriszstraat alphrn directe inzet 16162
--link: http://alarmeringen.nl/zuid-holland/hollands-midden/alphen-aan-den-rijn/?utm_source=rss&utm_medium=hollands-midden&utm_campaign=sharing
--description: Ambulance met gepaste spoed naar Pieter Floriszstraat in Alphen Aan Den Rijn
--pubDate: Fri, 09 Dec 2022 08:13:18 +0000
--result_table[i].description
--result_table[i].title
--result_table[i].pubDate
if result_table[i].description ~= nil then
-- Skip if Ambulance = voorwaarde scheppend to
if string.find( result_table[i].description, 'voorwaarde scheppend' ) == nil then
--This string is not found so continue
counter = counter + 1
if counter <= maxLines then
dz.log( '---------------- ', dz.LOG_DEBUG )
dz.log( 'Title: ' .. result_table[i].title, dz.LOG_DEBUG )
dz.log( 'Link: ' .. result_table[i].link, dz.LOG_DEBUG )
dz.log( 'Description: ' .. result_table[i].description, dz.LOG_DEBUG )
dz.log( 'pubDate: ' .. result_table[i].pubDate, dz.LOG_DEBUG )
-- date received. Format = Thu, 08 Dec 2022 01:37:39 +0000
local rowDate = dz.time.dateToDate( result_table[i].pubDate, 'ddd, dd mmm yyyy hh:MM:ss +0000', 'dd-mm-yyyy hh:MM', utcTimeDiffSeconds )
local rowLink = result_table[i].link
local rowTitle = result_table[i].title
-- trim off the cityName from description (case insensitive)
local rowDescription = string.gsub( result_table[i].description, ' in ' .. cityName, ".")
-- set rowImage based on description
local rowImage = imageDir .. '/icon_politie.webp' --Is default, because 'Politie' is often not used in description.
if string.find( result_table[i].description, "Ambulance") then rowImage = imageDir .. '/icon_ambulance.webp' end
if string.find( result_table[i].description, "Brandweer") then rowImage = imageDir .. '/icon_brandweer.webp' end
if string.find( result_table[i].description, "Politie") then rowImage = imageDir .. '/icon_politie.webp' end
dz.log( counter .. ': ' .. rowDate .. ' - ' .. rowDescription, dz.LOG_DEBUG )
-- Send notification when locationToSearch in in description
if string.find( result_table[i].description, locationToSearch ) then locationFound = true end
tableContent = tableContent .. ' <tr>\n' ..
' <td align="left" valign="middle" style="padding: 3px 10px 5px 10px">' .. rowDate .. '</td>\n' ..
' <td align="left" valign="middle" style="padding: 3px 10px 5px 10px"><a target="_blank" rel="noopener" href="' .. rowLink.. '"><img src="' .. rowImage.. '" style="width:34px; height:25px"></a></td> \n' ..
' <td align="left" valign="middle" style="padding: 3px 10px 5px 10px">'.. rowTitle .. '</br>' .. rowDescription .. '</td> \n' ..
' </tr> \n'
--Step 4. Append table footer with update time and close the table -----
local currentTime = dz.time.rawDateTime
local updateTime = dz.time.dateToDate( currentTime, 'yyyy-mm-dd hh:MM:ss', 'dd-mm-yyyy hh:MM', 0 )
dz.log( 'updateTime = ' .. updateTime, dz.LOG_DEBUG )
' <td colspan="3" align="right" style="padding: 3px 10px 3px 10px; color: cyan;">Update: ' .. updateTime .. ' uur</td>\n' ..
' </tr>\n' ..
' </table>\n'
--Step 5. Write tableContent ----------------
file:write(tableContent)
--Step 6. Write fileFooter ------------------
local fileFooter = ' </body>\n' ..
'</html>'
file:write(fileFooter)
--Step 7. Close file ------------------------
file:close()
-- Only one notification per session when location is found
--_d.lastAlarmNotification format = '2022-12-10'
-- dz.log( 'lastAlarmNotification = ' .. _d.lastAlarmNotification, dz.LOG_DEBUG )
if locationFound == true then
if _d.lastAlarmNotification == nil or _d.lastAlarmNotification < dz.time.rawDate then
_d.lastAlarmNotification = dz.time.rawDate
dz.log( locationToSearch .. ' found = ' .. tostring( locationFound ) .. ' on ' .. _d.lastAlarmNotification, dz.LOG_DEBUG )
dz.email( 'Alarmering.nl voor ' .. locationToSearch .. '!', '', al_emailTo, 0 )
Dz on Ubuntu VM on Proxmox behind FRITZ!Box.
EvoHome; MELCloud; P1 meter; Z-Stick GEN5; Z-Wave-js-ui; Sonoff USB-Dongle Plus-E; Zigbee2Mqtt; MQTT; Greenwave powernodes 1+6; Fibaro switch, plugs, smoke; FRITZ!DECT 200. Scripts listed in profile interests.
