Buienradarr "rain" keeps the same data
Ragdag
Post by Ragdag »
The Rain switch and RainByRate from Buienradarr seem to be stuck.
Since 3 days the Rain seems to be stuck, not sure how to troubleshoot this.
Looking at https://gpsgadget.buienradar.nl/data/raintext/ on my location gives
000|12:25
000|12:30
000|12:35
000|12:40
000|12:45
000|12:50
000|12:55
000|13:00
000|13:05
000|13:10
000|13:15
000|13:20
000|13:25
000|13:30
000|13:35
000|13:40
000|13:45
000|13:50
000|13:55
000|14:00
000|14:05
000|14:10
000|14:15
000|14:20
Because of this, the Rain Switch is also stuck while it is not raining.
Settings of Buienradarr
 2024-05-18 12:45:19.695 Status: BuienRadar: Worker stopped...
2024-05-18 12:45:19.695 Status: BuienRadar: using Domoticz location settings ()
2024-05-18 12:45:19.695 Status: BuienRadar: Worker started...
2024-05-18 12:45:26.904 BuienRadar: Temp + Humidity + Baro (TempHumBaro)
2024-05-18 12:45:26.914 BuienRadar: Temp (Ground Temperature (10 cm))
2024-05-18 12:45:26.922 BuienRadar: Temp (Feel Temperature)
2024-05-18 12:45:26.929 BuienRadar: General/Text (Weather Description)
2024-05-18 12:45:26.937 BuienRadar: Wind (Wind)
2024-05-18 12:45:26.944 BuienRadar: General/Visibility (Visibility)
2024-05-18 12:45:26.951 BuienRadar: General/Custom Sensor (Sun Power)
2024-05-18 12:45:26.963 BuienRadar: Rain (Rain)
2024-05-18 12:45:26.892 Status: BuienRadar: Nearest Station: Meetstation Gilze Rijen (Gilze Rijen)
2024-05-18 12:45:27.115 BuienRadar: General/Custom Sensor (Next Rainshower Leadtime)
2024-05-18 12:45:27.120 BuienRadar: General/Custom Sensor (Next Rainshower Duration)
2024-05-18 12:45:27.125 BuienRadar: General/Custom Sensor (Next Rainshower Avg Rainrate)
2024-05-18 12:45:27.129 BuienRadar: General/Custom Sensor (Next Rainshower Max Rainrate)
2024-05-18 12:45:27.135 BuienRadar: General/Percentage (Rain Intensity)
2024-05-18 12:45:27.145 BuienRadar: General/Custom Sensor (Regen aankomend uur)
Version: 2024.4 (build 15992)
Build Hash: 09a6f3d07
Compile Date: 2024-05-07 14:42:39
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Mar 12 2021, 04:06:34) [GCC 10.2.1 20210110]
Re: Buienradarr "rain" keeps the same data
Probably an issue at buienradar sending the wrong data.
For me it still works, the rain of today was nicely noted....
HansieNL
Post by HansieNL »
Can you try code 6350 for location. That should be the code of Meetstation Gilze Rijen.
Blah blah blah
Ragdag
Post by Ragdag »
I think it was a weird issue with the Gilze Rijen station, since yesterday evening it started working normal again.
