MQTTAD seems to loose track on MQTT broker ???
eddieb
Re: MQTTAD seems to loose track on MQTT broker ???
Post by eddieb »
Screenshot 2024-06-19 at 09.47.31.png (101.28 KiB) Viewed 999 times
not exactly sure what I should be looking for
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC with Node-Red and MQTT / SolarEdge SE3500H modbus_tcp / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Kedi
Post by Kedi »
The 1min number of messages/sent and publish/sent is quit big, but should not be a problem (approx. 200 per second)
I still might be that a devices sends bursts, or the Domoticz Hardware, the MQTT Gateway "prevent loop" setting set to false and should be true.
Did you check that?
eddieb
Post by eddieb »
yes, had that one for a couple of years allready, the famous Waaren helped me with that one while I was writing a nodered script to talk to my Airco
Screenshot 2024-06-19 at 20.46.26.png (34.58 KiB) Viewed 970 times
