- Screenshot 2024-06-19 at 09.47.31.png (101.28 KiB) Viewed 1001 times
MQTTAD seems to loose track on MQTT broker ???
Re: MQTTAD seems to loose track on MQTT broker ???
not exactly sure what I should be looking for
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC with Node-Red and MQTT / SolarEdge SE3500H modbus_tcp / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
The 1min number of messages/sent and publish/sent is quit big, but should not be a problem (approx. 200 per second)
I still might be that a devices sends bursts, or the Domoticz Hardware, the MQTT Gateway "prevent loop" setting set to false and should be true.
Did you check that?
Did you check that?
yes, had that one for a couple of years allready, the famous Waaren helped me with that one while I was writing a nodered script to talk to my Airco
