Adding custom how to
Posted: Monday 13 May 2024 21:31
by Tukker
I can use some advice about custom icons.
I learned from the wiki https://www.domoticz.com/wiki/Custom_ic ... binterface
At 11. it says I need to upload the new icons (which I downloaded from elsewhere) from _default.rar.
Unpacked and repacked the file to icons.zip
Here's the list of most of the icons present in the zip file.
When uploading Setup -> More Options -> Custom Items there is the following message.
Meanwhile one way or the other the uploaded icons can be located in ~/domoticz/www/images
So I added the uploaded icons to the file switch_icons.txt like
Alert;Alert;Alert
Azimuth;Azimuth;Azimuth
Blinds;Blinds;Blinds
Ice;Ice;Ice
Lux;Lux;Lux
Moisture;Moisture;Moisture
Override;Override;Override
Radiatio;Radiation;Radiation
Rain;Rain;Rain
Temp;Temp;Temp
Uv;Uv;Uv
Visibility;Visibility;Visibility
Wind;Wind;Wind
After a restart of Domoticz the icons seem more or less present.
Where did I go wrong and what to do to correct it.
Re: Adding custom icons
Posted: Tuesday 14 May 2024 0:33
The custom icon zip file must contain images and a text file that maps the images to a configuration.
But it seems you have downloaded a set of icons that should overwrite the existing icons in your installation folder domoticz/www/icons
So do not use the icons zip uploader tool but copy-paste and overwrite the new images directly in the folder domoticz/www/icons
Posted: Tuesday 14 May 2024 6:48
by habahabahaba
Oh.. didnt see you read it, sorry
Try the icon generator that described in Wiki. Works fine.
Posted: Tuesday 14 May 2024 9:01
HvdW wrote: Monday 13 May 2024 21:31 I can use some advice about custom icons.
You should not have unpacked and repacked those in one Zip. You should have imported the seperate zips one by one.
Posted: Wednesday 15 May 2024 0:25
by Tukker
Thanks very much for helping.
I had a problem reading that the zip file should contain the text file as well as the pics.
Everything fine now and changing icons within dzVents is working perfectly.
