Adding custom how to Topic is solved
Tukker
Domoticz version: 2023.2
Post by Tukker »
I can use some advice about custom icons.
I learned from the wiki https://www.domoticz.com/wiki/Custom_ic ... binterface
At 11. it says I need to upload the new icons (which I downloaded from elsewhere) from _default.rar.
Unpacked and repacked the file to icons.zip
Here's the list of most of the icons present in the zip file.
When uploading Setup -> More Options -> Custom Items there is the following message.
Meanwhile one way or the other the uploaded icons can be located in ~/domoticz/www/images
So I added the uploaded icons to the file switch_icons.txt like
Alert;Alert;Alert
Azimuth;Azimuth;Azimuth
Blinds;Blinds;Blinds
Ice;Ice;Ice
Lux;Lux;Lux
Moisture;Moisture;Moisture
Override;Override;Override
Radiatio;Radiation;Radiation
Rain;Rain;Rain
Temp;Temp;Temp
Uv;Uv;Uv
Visibility;Visibility;Visibility
Wind;Wind;Wind
After a restart of Domoticz the icons seem more or less present.
Where did I go wrong and what to do to correct it.
Bugs bug me.
Re: Adding custom icons
The custom icon zip file must contain images and a text file that maps the images to a configuration.
But it seems you have downloaded a set of icons that should overwrite the existing icons in your installation folder domoticz/www/icons
So do not use the icons zip uploader tool but copy-paste and overwrite the new images directly in the folder domoticz/www/icons
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
Oh.. didnt see you read it, sorry
Try the icon generator that described in Wiki. Works fine.
Last edited by habahabahaba on Tuesday 14 May 2024 10:25, edited 3 times in total.
HvdW wrote: Monday 13 May 2024 21:31 I can use some advice about custom icons.
You should not have unpacked and repacked those in one Zip. You should have imported the seperate zips one by one.
Tukker
Post by Tukker »
Thanks very much for helping.
I had a problem reading that the zip file should contain the text file as well as the pics.
Everything fine now and changing icons within dzVents is working perfectly.
Bugs bug me.
