Hello all,
I am partially answering myself.
By adding 'timeout=5' in requests.get Domoticz no longer crashes but I have a long list of errors in the log:
2024-05-10 11:07:23.092 Error: Traceback (most recent call last):
2024-05-10 11:07:23.092 Error: File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 536, in _make_request
2024-05-10 11:07:23.092 Error: response = conn.getresponse()
2024-05-10 11:07:23.092 Error: File "/usr/local/lib/python3.9/dist-packages/urllib3/connection.py", line 461, in getresponse
2024-05-10 11:07:23.092 Error: httplib_response = super().getresponse()
2024-05-10 11:07:23.092 Error: File "/usr/lib/python3.9/http/client.py", line 1347, in getresponse
2024-05-10 11:07:23.092 Error: response.begin()
2024-05-10 11:07:23.092 Error: File "/usr/lib/python3.9/http/client.py", line 307, in begin
2024-05-10 11:07:23.092 Error: version, status, reason = self._read_status()
2024-05-10 11:07:23.092 Error: File "/usr/lib/python3.9/http/client.py", line 268, in _read_status
2024-05 -10 11:07:23.092 Error: line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
2024-05-10 11:07:23.092 Error: File "/usr/lib/python3.9/socket.py", line 704, in readinto
2024-05-10 11:07:23.092 Error: return self._sock.recv_into(b)
2024-05-10 11:07:23.092 Error: socket.timeout: timed out
2024-05-10 11:07:23.092 Error: The above exception was the direct cause of the following exception:
2024-05-10 11:07:23.092 Error: File "/usr/local/lib/python3.9/dist-packages/requests/adapters.py", line 486, in send
2024-05-10 11:07:23.092 Error: resp = conn.urlopen(
2024-05-10 11:07:23.092 Error: File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 844, in urlopen
2024-05-10 11:07:23.092 Error: retries = retries.increment(
2024-05-10 11:07:23.092 Error: File "/usr/local/li b/python3.9/dist-packages/urllib3/util/retry.py", lin e 470, in increment
2024-05-10 11:07:23.092 Error: raise reraise(type(error), error, _stacktrace)
2024-05-10 11:07:23.092 Error: File "/usr/local/lib/python3.9/dist-packages/urllib3/util/util.py", line 39, in reraise
2024-05-10 11:07:23.092 Error: raise value
2024-05-10 11:07:23.092 Error: File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 790, in urlopen
2024-05-10 11:07:23.092 Error: response = self._make_request(
2024-05-10 11:07:23.092 Error: File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 538, in _make_request
2024-05-10 11:07:23.092 Error: self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
2024-05-10 11:07:23.092 Error: File "/usr/local/lib/python3.9/dist-packages/urllib3/connectionpool.py", line 370, in _raise_timeout
2024-05-10 11:07:23.092 Error: raise ReadTimeoutError(
2024-05-10 11:07:23.092 Error: urllib3.exceptions.ReadTimeoutError: HT TPConnectionPool(host='192.168.0.45', port=18080): Read timed out. (read timeout=3)
2024-05-10 11:07:23.092 Error: During handling of the above exception, another exception occurred:
2024-05-10 11:07:23.092 Error: File "MQTTpublishPG.py", line 45, in
2024-05-10 11:07:23.092 Error: File "/usr/local/lib/python3.9/dist-packages/requests/api.py", line 73, in get
2024-05-10 11:07:23.092 Error: return request("get", url, params=params, **kwargs)
2024-05-10 11:07:23.092 Error: File "/usr/local/lib/python3.9/dist-packages/requests/api.py", line 59, in request
2024-05-10 11:07:23.092 Error: return session.request(method=method, url=url, **kwargs)
2024-05-10 11:07:23.092 Error: File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 589, in request
2024-05-10 11:07:23.092 Error: resp = self.send(prep, **send_kwargs)
2024-05-1 0 11:07:23.092 Error: File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 703, in send
2024-05-10 11:07:23.092 Error: r = adapter.send(request, **kwargs)
2024-05-10 11:07:23.092 Error: File "/usr/local/lib/python3.9/dist-packages/requests/adapters.py", line 532, in send
2024-05-10 11:07:23.092 Error: raise ReadTimeout(e, request=request)
2024-05-10 11:07:23.092 Error: requests.exceptions.ReadTimeout: HTTPConnectionPool(host='192.168.0.45', port=18080): Read timed out. (read timeout=3)
How to avoid these errors ?
