Z-wave usage figures are strange
Posted: Monday 06 May 2024 15:09
by pkelderman
I'm using Neo coolcam switches by means of zwave js ui (finally!!!). One off these switches I use to monitor my heat pump. That device uses 8 watt per hour and short some watts more. So per day 24 * 10 = 250 Watt. Domoticz reports 500-600 Watt. That seems to me a bug. But perhaps I'm doing something wrong. Someone any idea :?: Btw the old zwave gives the same result.
Re: Z-wave usage figures are strange
Posted: Monday 06 May 2024 18:46
by waltervl
Then it is probably the device itself that gives these values. Check the values coming out of Zwave-JS-UI with mqtt explorer.
Also Domoticz is not good in calculating ultra low energy levels.
Posted: Tuesday 07 May 2024 16:23
by pkelderman
I get the feeling that the values ​​are rounded off. And that's a shame in my case. The device does provide the expected values. Isn't possible Domoticz is giving more accurate calculations? Thanks anyway for your answer.
Posted: Wednesday 15 May 2024 21:45
by pkelderman
I had to use (again) the possibility after switch to zwave jsui to let domoticz compute the requested values. So problem solved!
