invalid device active state after switchOn or switchOff
Sjoko
Domoticz version: 2023.2
Post by Sjoko »
In DzVents time triggered script,
immediately after switchOn a device, the active status is still false.
switchEventTestSwich.switchOn()
if switchEventTestSwich.active then
... never getting here
On next run of the script, the active status is correct.
Am I missing something ?
I have isolated this problem in the following script;
		timer = {
			'every minute',				-- causes the script to be called every minute
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'switchOnAndActive',
	execute = function(domoticz, timer)
		domoticz.log('Timer event was triggered by ' .. timer.trigger, domoticz.LOG_INFO)
		local switchEventTestSwich = domoticz.devices(113);
		    switchEventTestSwich.switchOff()
		        domoticz.log('switchEventTestSwich: active but switchOff', domoticz.LOG_ERROR)
		        domoticz.log('switchEventTestSwich: not active and switchOff', domoticz.LOG_INFO)
		        domoticz.log('switchEventTestSwich: active and switchOn', domoticz.LOG_INFO)
		        domoticz.log('switchEventTestSwich: not active but switchOn', domoticz.LOG_ERROR)
Logging output;
2024-04-25 10:36:00.384 Status: dzVents: Info: switchOnAndActive: ------ Start internal script: Script #test switchOnAndActive:, trigger: "every minute"
2024-04-25 10:36:00.385 Status: dzVents: Info: switchOnAndActive: Timer event was triggered by every minute
2024-04-25 10:36:00.388 Status: dzVents: Info: switchOnAndActive: ------ Finished Script #test switchOnAndActive
2024-04-25 10:36:00.387 Error: dzVents: Error: (3.1.8) switchOnAndActive: switchEventTestSwich: active but switchOff
2024-04-25 10:37:00.393 Status: dzVents: Info: switchOnAndActive: ------ Start internal script: Script #test switchOnAndActive:, trigger: "every minute"
2024-04-25 10:37:00.394 Status: dzVents: Info: switchOnAndActive: Timer event was triggered by every minute
2024-04-25 10:37:00.396 Status: dzVents: Info: switchOnAndActive: ------ Finished Script #test switchOnAndActive
2024-04-25 10:37:00.395 Error: dzVents: Error: (3.1.8) switchOnAndActive: switchEventTestSwich: not active but switchOn
my system:
Linux pi 5.15.84-v7+ #1613 SMP Thu Jan 5 11:59:48 GMT 2023 armv7l GNU/Linux
Version: 2023.2
Build Hash: 19efd039c
Compile Date: 2023-07-21 17:23:44
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Mar 12 2021, 04:06:34) [GCC 10.2.1 20210110]
boum
Domoticz version: 4.10717
Re: invalid device active state after switchOn or switchOff
Post by boum »
this have been told several time. changes to device states (and probably user variables) are done after the script execution. (that's a good way to avoid infinite loops by the way)
during the execution of the script the states are fixed. if you want to track your changes for later use in the same script, use a local variable
Sjoko
Post by Sjoko »
thanks for the quick reply and the clear explanation.
