Blockly react on calculated values
njlammerts
Domoticz version: 2022.2
Post by njlammerts »
Is there a way to let the outcome of a blocky script be dependent on a calculation of measurements?
I have a 3 way valve which I want to open when the temperature of a sensor is say 20C + 5 and close on the same value - 3.
I have it now solved by edit the sensor adjustment value with +5, so the value is alway 5C off
Re: Blockly react on calculated values
Blockly cannot do math. You have to switch to Dzvents to do something like this.
