MOES blind motor cannot be added to Domotics (processNotinDBDevices) Topic is solved
Cizetta
Post by Cizetta »
I have three such blind motors - https://moeshouse.com/products/zigbee-c ... inds-motor.
I've added them to Domoticz-Zigbee and control them via Domoticz - no issues with them.
Recently I bough three additional ones - same model, same seller. There is no difference in the models, the new ones are manufactured 5 months after the old ones. And I hit an error trying to add them in Domoticz-Zigbee:
2024-03-31 18:24:59.129 Error: Zigbee: processNotinDBDevices - Creat Domo Device Failed !!! for 65b6 status: 8043
Old motors' model is recognized as "TS0601-curtain", the new ones are recognized just as "TS0601" (newer firmware?).
Here is part of the Domoticz log:
2024-03-31 18:24:43.989 Status: Zigbee: [None] NEW OBJECT: 65b6 None
2024-03-31 18:24:44.970 Zigbee: Assisted Pairing: Polling: ['65b6']
2024-03-31 18:24:44.970 Zigbee: --> New device: 65b6
2024-03-31 18:24:44.580 Status: Zigbee: [-] NEW OBJECT: 65b6 Active Endpoint Response Ep: 01 LQI: 0
2024-03-31 18:24:44.590 Status: Zigbee: [-] NEW OBJECT: 65b6 Request Simple Descriptor for Ep: 01
2024-03-31 18:24:45.529 Status: Zigbee: [-] NEW OBJECT: 65b6 Simple Descriptor Response EP: 0x01 LQI: 0
2024-03-31 18:24:45.530 Status: Zigbee: [-] NEW OBJECT: 65b6 ProfileID 0104
2024-03-31 18:24:45.531 Status: Zigbee: [-] NEW OBJECT: 65b6 ZDeviceID 0051
2024-03-31 18:24:45.532 Status: Zigbee: [-] NEW OBJECT: 65b6 Application Version 0001
2024-03-31 18:24:45.533 Status: Zigbee: [-] NEW OBJECT: 65b6 Cluster IN Count: 04
2024-03-31 18:24:45.535 Status: Zigbee: [-] NEW OBJECT: 65b6 Cluster In 1: 0000 (Basic)
2024-03-31 18:24:45.536 Status: Zigbee: [-] NEW OBJECT: 65b6 Cluster In 2: 0004 (Groups)
2024-03-31 18:24:45.537 Status: Zigbee: [-] NEW OBJECT: 65b6 Cluster In 3: 0005 (Scenes)
2024-03-31 18:24:45.539 Status: Zigbee: [-] NEW OBJECT: 65b6 Cluster In 4: ef00
2024-03-31 18:24:45.540 Status: Zigbee: [-] NEW OBJECT: 65b6 Cluster OUT Count: 02
2024-03-31 18:24:45.541 Status: Zigbee: [-] NEW OBJECT: 65b6 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2024-03-31 18:24:45.541 Status: Zigbee: [-] NEW OBJECT: 65b6 Cluster Out 2: 000a (Time)
2024-03-31 18:24:48.059 Living Room Air Purifier: onHeartbeat called
2024-03-31 18:24:49.095 Status: Zigbee: [1] NEW OBJECT: 65b6 Model Name: TS0601
2024-03-31 18:24:49.099 Status: Zigbee: [1] NEW OBJECT: 65b6 Manufacturer Name: _TZE200_icka1clh
2024-03-31 18:24:49.111 Status: Zigbee: [None] NEW OBJECT: 65b6 Request Node Descriptor
2024-03-31 18:24:54.066 Status: Zigbee: [2] NEW OBJECT: 65b6 Model Name: TS0601
2024-03-31 18:24:54.072 Status: Zigbee: [2] NEW OBJECT: 65b6 Manufacturer Name: _TZE200_icka1clh
2024-03-31 18:24:55.678 Zigbee: Assisted Pairing: Polling: ['65b6']
2024-03-31 18:24:55.678 Zigbee: --> New device: 65b6
2024-03-31 18:24:58.093 Living Room Air Purifier: onHeartbeat called
2024-03-31 18:24:59.100 Status: Zigbee: [3] NEW OBJECT: 65b6 Model Name: TS0601
2024-03-31 18:24:59.104 Status: Zigbee: [3] NEW OBJECT: 65b6 Manufacturer Name: _TZE200_icka1clh
Here is a screenshot from my test Domoticz with Zigbee setup:
I'm using latest version of the plugin -
Plugin: 7.1.011 [4.246]
and latest Domoticz Beta -
Version: 2024.4 (build 15910)
Am I missing something with the configuration? Could this be fixed in future versions?
I can provide additional information and logs if required.
Thank you in advance!
pipiche
Re: MOES blind motor cannot be added to Domotics (processNotinDBDevices)
Post by pipiche »
can you try to update the plugin to get [4.249] , and the you redo the pairing
Cizetta
Post by Cizetta »
You're great! It works now! Thank you a lot!
patdu31
Post by patdu31 »
I have the same issue with the module MOES Smart Dimmer Module one gang.
I'm able to pair it into the Zigbee admin webpage but it is not added into Domoticz.
I've found the following logs:
2024-09-07 13:19:37.340 Status: Zigbee: [None] NEW OBJECT: 3f2b None
2024-09-07 13:19:38.644 Status: Zigbee: [-] NEW OBJECT: 3f2b Active Endpoint Response Ep: 01 LQI: 0
2024-09-07 13:19:38.645 Status: Zigbee: [-] NEW OBJECT: 3f2b Request Simple Descriptor for Ep: 01
2024-09-07 13:19:38.829 Status: Zigbee: [-] NEW OBJECT: 3f2b Simple Descriptor Response EP: 0x01 LQI: 0
2024-09-07 13:19:38.830 Status: Zigbee: [-] NEW OBJECT: 3f2b ProfileID 0104
2024-09-07 13:19:38.831 Status: Zigbee: [-] NEW OBJECT: 3f2b ZDeviceID 0051
2024-09-07 13:19:38.832 Status: Zigbee: [-] NEW OBJECT: 3f2b Application Version 0001
2024-09-07 13:19:38.833 Status: Zigbee: [-] NEW OBJECT: 3f2b Cluster IN Count: 04
2024-09-07 13:19:38.833 Status: Zigbee: [-] NEW OBJECT: 3f2b Cluster In 1: 0000 (Basic)
2024-09-07 13:19:38.834 Status: Zigbee: [-] NEW OBJECT: 3f2b Cluster In 2: 0004 (Groups)
2024-09-07 13:19:38.835 Status: Zigbee: [-] NEW OBJECT: 3f2b Cluster In 3: 0005 (Scenes)
2024-09-07 13:19:38.836 Status: Zigbee: [-] NEW OBJECT: 3f2b Cluster In 4: ef00
2024-09-07 13:19:38.837 Status: Zigbee: [-] NEW OBJECT: 3f2b Cluster OUT Count: 02
2024-09-07 13:19:38.838 Status: Zigbee: [-] NEW OBJECT: 3f2b Cluster Out 1: 0019 (Over-the-Air Upgrade)
2024-09-07 13:19:38.839 Status: Zigbee: [-] NEW OBJECT: 3f2b Cluster Out 2: 000a (Time)
2024-09-07 13:19:42.064 Status: Zigbee: [0] NEW OBJECT: 3f2b Model Name: TS0601
2024-09-07 13:19:42.065 Status: Zigbee: [0] NEW OBJECT: 3f2b Manufacturer Name: _TZE200_la2c2uo9
2024-09-07 13:19:42.066 Status: Zigbee: [None] NEW OBJECT: 3f2b Request Node Descriptor
2024-09-07 13:19:47.091 Status: Zigbee: [1] NEW OBJECT: 3f2b Model Name: TS0601
2024-09-07 13:19:47.093 Status: Zigbee: [1] NEW OBJECT: 3f2b Manufacturer Name: _TZE200_la2c2uo9
2024-09-07 13:19:52.105 Status: Zigbee: [2] NEW OBJECT: 3f2b Model Name: TS0601
2024-09-07 13:19:52.111 Status: Zigbee: [2] NEW OBJECT: 3f2b Manufacturer Name: _TZE200_la2c2uo9
2024-09-07 13:19:57.076 Status: Zigbee: [3] NEW OBJECT: 3f2b Model Name: TS0601
2024-09-07 13:19:57.078 Status: Zigbee: [3] NEW OBJECT: 3f2b Manufacturer Name: _TZE200_la2c2uo9
2024-09-07 13:19:57.084 Error: Zigbee: processNotinDBDevices - Creat Domo Device Failed !!! for 3f2b status: 8043
2024-09-07 12:57:39.068 Error: Zigbee: processNotinDBDevices - Creat Domo Device Failed !!! for 251b status: 8043
2024-09-07 13:07:58.994 Error: Zigbee: This device is not correctly configured, please contact us with the here after information
2024-09-07 13:07:59.025 Error: Zigbee: - Device 251b
2024-09-07 13:07:59.059 Error: Zigbee: - Model TS0601
2024-09-07 13:07:59.114 Error: Zigbee: - Manufacturer _TZE200_la2c2uo9
2024-09-07 13:08:47.105 Error: Zigbee: No nameservers found for zigate_plugin.pipiche.net
2024-09-07 13:08:47.150 Error: Zigbee: Unable to get access to plugin expected version. Is Internet access available ?
2024-09-07 13:13:23.534 Error: Zigbee: forwarder_thread - Error while receiving a Coordinator command
2024-09-07 13:13:23.572 Error: Zigbee: Issue in request 0180020032ff00000000130000020cfa02000084fa0ce4a1eefeffb15c6c8e0003, dumping stack: Traceback (most recent call last):
Domoticz version 2024.7 stable
Zigbee admin page version 7.1.012
Plugin version : 5.307
What I have to do to support and add the device into Domoticz?
Patrick
pipiche
Post by pipiche »
Kind update the plugin you need to get the Certified Db version 5.308, get the plugin restarted and running with that version, and then do the pairing again.
patdu31
Post by patdu31 »
Thank you very much pipiche for your support, you rock!
I did the update, launch the pairing and the device is not displayed into Domoticz.
It's works like a charm, I can do on/off on the light and adjust the level correctly.
Enjoy your sunday!
Logs:
2024-09-08 12:44:52.077 Status: Zigbee: [0] NEW OBJECT: 0873 Model Name: TS0601-dimmer
2024-09-08 12:44:52.083 Status: Zigbee: [0] NEW OBJECT: 0873 Manufacturer Name: _TZE200_la2c2uo9
2024-09-08 12:44:52.084 Status: Zigbee: [None] NEW OBJECT: 0873 Request Node Descriptor
pipiche
Post by pipiche »
Thanks for the feedback
