dzVents error parsing json to LUA table
Posted: Sunday 24 March 2024 22:39
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Codename: buster
Dz Version: 2022.2
Build Hash: eea9db734
Compile Date: 2022-11-05 13:05:35
dzVents Version: 3.1.8
Python Version: 3.7.3 (default, Jun 29 2023, 18:03:57) [GCC 8.3.0]
After Enphase found it necessary to place an unsolicited update on my Envoy, the dzVenst script that I have been using for years no longer works due to the token that is now required. So looking for an alternative solution that works under an older version of Dz (2021.1).
The reason for the latter is because it runs a Modbus RTU script that no longer functions on Dz >=2023.x viewtopic.php?p=315320#p315320 I have not been able to solve that issue yet. Conversely, the Envoy script does not run on older versions of Dz because there is still no option to enter the Enphase token <2023.x.
So I'm now looking for a solution vieuwed from the other side (di Dz 2021.1).
The end goal is that at least both scripts can run on the same version of Dz so the data from both can be used for calculations. This means the ratio between solar radiation (Modbus RTU serial to USB) and the yield of the solar panels (from the Envoy from Enphase).
I've come quite far, but am now encountering an error message that I don't understand much about.
These are the scripts.
Script1:
Script2:
Calling the second script seems to work fine. I also see the searched data in the Dz log. Under the Error tab, that is. Devices are not updated so I can't use it as input for calculations yet.
This is the output on ERROR tab of Dz log:
I think I'm very close to the solution. Presumably something goes wrong after the line that says 'marker = '031 Log PVProduction' in the second script.
However, I don't know enough about dzVents or json to be able to solve this. Who sees where this goes wrong/can help solve this issue?
Release: 10
Codename: buster
Dz Version: 2022.2
Script1:
local curlStatement = 'curl -f -k -H \'Authorization: Bearer '
local envoyUrl = 'https://My IP'
local envoyEndPoint = '/ivp/pdm/energy'
local tokenVar = 'MyToken'
local curlCommand = 'leeg'
timer = {
'every 1 minutes',
'at *:08', 'at *:23',
'at *:38', 'at *:53'
logging = {
level = domoticz.LOG_INFO,
marker = '003 Get PVProduction'
execute = function (domoticz)
curlCommand = curlStatement .. tokenVar .. '\' ' .. envoyUrl .. envoyEndPoint
domoticz.executeShellCommand ({
command = curlCommand,
callback = 'productiePanelen',
timeout = 20
domoticz.log (curlCommand)
domoticz.log ('Triggering 030 Log zonnepanelen productie')
local zonnepanelenNowIdx = 851 -- Dummy Custom Sensor
local zonnepanelenTodayIdx = 852 -- Dummy Custom Sensor
local zonnepanelenSevenDaysIdx = 853 -- Dummy Custom Sensor
local zonnepanelenLifetimeIdx = 854 -- Dummy Custom Sensor
local wattsNow
local wattHoursToday
local wattHoursSevenDays
local wattHoursLifetime
shellCommandResponses = {'productiePanelen'}
logging = {
execute = function (domoticz, item)
domoticz.log ('Triggered by 003 Get PV Production')
if item.statusCode ~= 0 then domoticz.log ("item.statusCode: " .. item.statusCode) end
if item.json ~= nil
then
wattsNow = item.json .wattsNow
wattHoursToday = domoticz.utils.round((item.json .wattHoursToday / 1000), 2)
wattHoursSevenDays = domoticz.utils.round((item.json .wattHoursSevenDays / 1000), 2)
wattHoursLifetime = domoticz.utils.round((item.json .wattHoursLifetime / 1000000), 2)
domoticz.devices (zonnepanelenNowIdx) .updateCustomSensor (wattsNow)
domoticz.devices (zonnepanelenTodayIdx) .updateCustomSensor (wattHoursToday)
domoticz.devices (zonnepanelenSevenDaysIdx) .updateCustomSensor (wattHoursSevenDays)
domoticz.devices (zonnepanelenLifetimeIdx) .updateCustomSensor (wattHoursLifetime)
domoticz.log ('Opbrengst Nu........: ' .. item.json.wattsNow .. ' Watt')
domoticz.log ('Opbrengst Vandaag...: ' .. wattHoursToday .. ' kWh')
domoticz.log ('Opbrengst 7 dagen...: ' .. wattHoursSevenDays .. ' kWh')
domoticz.log ('Opbrengst Lifetime..: ' .. wattHoursLifetime .. ' MWh')
domoticz.log ('item.json == nil')
2024-03-24 22:34:01.147 Error: dzVents: Error: (3.1.8) 031 Log PVProduction: Error parsing json to LUA table: /home/pi/domoticz/dzVents/runtime/JSON.lua:1234: /home/pi/domoticz/dzVents/runtime/JSON.lua:808: expected comma or '}' at byte 710 of: {
2024-03-24 22:34:01.147 "production": {
2024-03-24 22:34:01.147 "pcu": {
2024-03-24 22:34:01.147 "wattHoursToday": 12516,
2024-03-24 22:34:01.147 "wattHoursSevenDays": 106246,
2024-03-24 22:34:01.147 "wattHoursLifetime": 23428351,
2024-03-24 22:34:01.147 "wattsNow": 0
2024-03-24 22:34:01.147 },
2024-03-24 22:34:01.147 "rgm": {
2024-03-24 22:34:01.147 "wattHoursToday": 0,
2024-03-24 22:34:01.147 "wattHoursSevenDays": 0,
2024-03-24 22:34:01.147 "wattHoursLifetime": 0,
2024-03-24 22:34:01.147 "eim": {
2024-03-24 22:34:01.147 "consumption": {
2024-03-24 22:34:01.147 }However, I don't know enough about dzVents or json to be able to solve this. Who sees where this goes wrong/can help solve this issue?
