Release: 10
Codename: buster
Dz Version: 2022.2
Build Hash: eea9db734
Compile Date: 2022-11-05 13:05:35
dzVents Version: 3.1.8
Python Version: 3.7.3 (default, Jun 29 2023, 18:03:57) [GCC 8.3.0]
After Enphase found it necessary to place an unsolicited update on my Envoy, the dzVenst script that I have been using for years no longer works due to the token that is now required. So looking for an alternative solution that works under an older version of Dz (2021.1).
The reason for the latter is because it runs a Modbus RTU script that no longer functions on Dz >=2023.x viewtopic.php?p=315320#p315320 I have not been able to solve that issue yet. Conversely, the Envoy script does not run on older versions of Dz because there is still no option to enter the Enphase token <2023.x.
So I'm now looking for a solution vieuwed from the other side (di Dz 2021.1).
The end goal is that at least both scripts can run on the same version of Dz so the data from both can be used for calculations. This means the ratio between solar radiation (Modbus RTU serial to USB) and the yield of the solar panels (from the Envoy from Enphase).
I've come quite far, but am now encountering an error message that I don't understand much about.
These are the scripts.
Script1:
local curlStatement = 'curl -f -k -H \'Authorization: Bearer '
local envoyUrl = 'https://My IP'
local envoyEndPoint = '/ivp/pdm/energy'
local tokenVar = 'MyToken'
local curlCommand = 'leeg'
timer = {
'every 1 minutes',
'at *:08', 'at *:23',
'at *:38', 'at *:53'
logging = {
level = domoticz.LOG_INFO,
marker = '003 Get PVProduction'
execute = function (domoticz)
curlCommand = curlStatement .. tokenVar .. '\' ' .. envoyUrl .. envoyEndPoint
domoticz.executeShellCommand ({
command = curlCommand,
callback = 'productiePanelen',
timeout = 20
domoticz.log (curlCommand)
domoticz.log ('Triggering 030 Log zonnepanelen productie')
local zonnepanelenNowIdx = 851 -- Dummy Custom Sensor
local zonnepanelenTodayIdx = 852 -- Dummy Custom Sensor
local zonnepanelenSevenDaysIdx = 853 -- Dummy Custom Sensor
local zonnepanelenLifetimeIdx = 854 -- Dummy Custom Sensor
local wattsNow
local wattHoursToday
local wattHoursSevenDays
local wattHoursLifetime
shellCommandResponses = {'productiePanelen'}
logging = {
marker = '031 Log PVProduction'
execute = function (domoticz, item)
domoticz.log ('Triggered by 003 Get PV Production')
if item.statusCode ~= 0 then domoticz.log ("item.statusCode: " .. item.statusCode) end
if item.json ~= nil
then
wattsNow = item.json .wattsNow
wattHoursToday = domoticz.utils.round((item.json .wattHoursToday / 1000), 2)
wattHoursSevenDays = domoticz.utils.round((item.json .wattHoursSevenDays / 1000), 2)
wattHoursLifetime = domoticz.utils.round((item.json .wattHoursLifetime / 1000000), 2)
domoticz.devices (zonnepanelenNowIdx) .updateCustomSensor (wattsNow)
domoticz.devices (zonnepanelenTodayIdx) .updateCustomSensor (wattHoursToday)
domoticz.devices (zonnepanelenSevenDaysIdx) .updateCustomSensor (wattHoursSevenDays)
domoticz.devices (zonnepanelenLifetimeIdx) .updateCustomSensor (wattHoursLifetime)
domoticz.log ('Opbrengst Nu........: ' .. item.json.wattsNow .. ' Watt')
domoticz.log ('Opbrengst Vandaag...: ' .. wattHoursToday .. ' kWh')
domoticz.log ('Opbrengst 7 dagen...: ' .. wattHoursSevenDays .. ' kWh')
domoticz.log ('Opbrengst Lifetime..: ' .. wattHoursLifetime .. ' MWh')
domoticz.log ('item.json == nil')
This is the output on ERROR tab of Dz log:
2024-03-24 22:34:01.147 Error: dzVents: Error: (3.1.8) 031 Log PVProduction: Error parsing json to LUA table: /home/pi/domoticz/dzVents/runtime/JSON.lua:1234: /home/pi/domoticz/dzVents/runtime/JSON.lua:808: expected comma or '}' at byte 710 of: {
2024-03-24 22:34:01.147 "production": {
2024-03-24 22:34:01.147 "pcu": {
2024-03-24 22:34:01.147 "wattHoursToday": 12516,
2024-03-24 22:34:01.147 "wattHoursSevenDays": 106246,
2024-03-24 22:34:01.147 "wattHoursLifetime": 23428351,
2024-03-24 22:34:01.147 "wattsNow": 0
2024-03-24 22:34:01.147 },
2024-03-24 22:34:01.147 "rgm": {
2024-03-24 22:34:01.147 "wattHoursToday": 0,
2024-03-24 22:34:01.147 "wattHoursSevenDays": 0,
2024-03-24 22:34:01.147 "wattHoursLifetime": 0,
2024-03-24 22:34:01.147 "eim": {
2024-03-24 22:34:01.147 "consumption": {
However, I don't know enough about dzVents or json to be able to solve this. Who sees where this goes wrong/can help solve this issue?
