IKEA Styrbar script
DewGew
Domoticz version: V4.10618
IKEA Styrbar script
Post by DewGew »
I want to share my zigbee IKEA styrbar dimmer script. I use zigbee2MQTT and zigbee2MQTT plugin v3.2.0.
I tryed with MQTT AD but I got alot of on/off devices instead of 1 selector switch.
-- Settings --
local dimmerIdx = 123 -- change to idx of your IKEA selector / dimmerswitch
local deviceIdx = 45  -- change to idx of you light/switch
local delta = 20      -- level steps for brightness
return
    on =
        devices =
            dimmerIdx,
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'IKEA Styrbar / selector',
    ** IKEA Styrbar Levelnames **
    'on'
    'off'
    'brightness_move_up'
    'brightness_move_down'
    'brightness_stop'
    'arrow_left_click'
    'arrow_right_click'
    'arrow_left_hold'
    'arrow_right_hold'
    'arrow_left_release'
    'arrow_right_release'
    'Off'
    execute = function(dz, styrbar)
        local deviceToSwitch = dz.devices(deviceIdx)
        dz.log('Device ' .. styrbar.name .. ' updated. Last level was ' .. styrbar.lastLevel .. '; new level is ' .. styrbar.level .. ' (' .. styrbar.state .. ')', dz.LOG_DEBUG)
        dimlevel = deviceToSwitch.level
        if styrbar.state == 'on' then
            deviceToSwitch.switchOn()
        if styrbar.state == 'brightness_move_up' then
            deviceToSwitch.dimTo(dimlevel + delta)
        if styrbar.state == 'off' then
            deviceToSwitch.switchOff()
        if styrbar.state == 'brightness_move_down' then
            deviceToSwitch.dimTo(dimlevel-delta)
Domoticz version: 2024.7
Re: IKEA Styrbar script
Something similar should also work with MQTT AD. You only have to trigger on all those button devices instead of the levels.
DewGew
Post by DewGew »
waltervl wrote: Thursday 14 March 2024 8:10 Something similar should also work with MQTT AD. You only have to trigger on all those button devices instead of the levels.
Problem is that I have to add 11 dimmerIdx instead of 1
BazemanKM
Post by BazemanKM »
DewGew wrote: Friday 15 March 2024 18:21
To add 11* IDX or 11* levelname in the script seems not a lot of difference....
Only saying that for the users of MQTT AD that that should not be a deal breaker to change to the plugin. Although I like the plugin way of working better too.
