News not working anymore Topic is solved
michelscholte
Post by michelscholte »
News block with the default 'http://www.nu.nl/rss/Algemeen' is not working since this morning. No errors in console log, only a blank block.
Any ideas?
HansieNL
Re: News not working anymore
Post by HansieNL »
Just tried a block with 'http://www.nu.nl/rss/Algemeen' and no problem.
If you got a complex config try to disable some parts and see if the news feed is working again. This way you can try to find the cause of the error.
Blah blah blah
michelscholte
Thanks for your reply.
Problem is solved. I use a VPN proxy. It seems that nu.nl is not accessible through this proxy anymore.
