Extended Python Framework - Updating SwitchType, Type and SubType
pipiche
Post by pipiche »
There is an issue, when with the Extended Domotciz framework you update Type, SwitchType and Subtype
With the attached plugin it creates a device, but then when you are updating switchtype .... it create a 2nd entry in the DeviceStatus
26|13|Test Widget|1|Test Widget 1|0|241|7|8|0|12|255|0||2024-02-13 18:55:01|26|0.0|1.0|0.0|1.0|||0|0|0||||0
27|13|Test Widget|1|Test Widget 1|0|244|73|0|0|12|255|0||2024-02-13 18:54:31|27|0.0|1.0|0.0|1.0|||0|0|0||||0
<plugin key="UpdateType" name="Updating SwitchType ..." author="pipiche" version="0.1" externallink="">
    <params>
        <param field="Mode6" label="Debugging" width="150px"  default="None" required="true">
            <description><br/><h3>Plugin debug</h3>This debugging option has been moved to the WebUI > Tools > Debug<br/></description>
                <options>
                    <option label="None" value="0"  default="true" />
                    <option label="Python Only" value="2"/>
                    <option label="Basic Debugging" value="62"/>
                    <option label="Basic+Messages" value="126"/>
                    <option label="Connections Only" value="16"/>
                    <option label="Connections+Queue" value="144"/>
                    <option label="All" value="-1"/>
                </options>
        </param>
    </params>
</plugin>
HEARTBEAT_FEQ = 30
NUMBER_UNIT = 1
import DomoticzEx as Domoticz
DOMOTICZ_EXTENDED_API = True
DEVICE_ID = "Test Widget"
class BasePlugin:
    def __init__(self):
        self.plugin_ready = False
        self.count = 0
        return
    def onStart(self):
        Domoticz.Log('onStart called %s' % DOMOTICZ_EXTENDED_API)
        for unit in range(0, NUMBER_UNIT):
            device_unit = unit +1
            device_create_unit(self, Devices, DEVICE_ID, "Test Widget %s" % device_unit, device_unit)
        # Set plugin heartbeat to 1s
        Domoticz.Heartbeat(HEARTBEAT_FEQ)
    def onHeartbeat(self):
        Domoticz.Debug('onHeartbeat called')
            if self.count % 2 == 0:
                domo_update_witchType_SubType_Type(self, Devices, DEVICE_ID, device_unit, Type_=244, Subtype_=73, Switchtype_=0)
            else:
                domo_update_witchType_SubType_Type(self, Devices, DEVICE_ID, device_unit, Type_=241, Subtype_=7, Switchtype_=7)
        self.count += 1
    def onCommand(self, Unit, Command, Level, Hue):
        Domoticz.Debug('onCommand called')
    def onStop(self):
        Domoticz.Debug('onStop called')
def device_create_unit(self, Devices, deviceId, Name, unit):
    if DOMOTICZ_EXTENDED_API:
        if deviceId in Devices and unit in Devices[deviceId].Units:
            return
    elif not DOMOTICZ_EXTENDED_API and unit in Devices:
        return
    Domoticz.Log('device_create_unit %s %s/%s' % (Name, deviceId ,unit))
    domoticz_device_api_class = Domoticz.Unit if DOMOTICZ_EXTENDED_API else Domoticz.Device
    myDev = domoticz_device_api_class(Name=str(Name),DeviceID=str(deviceId), Unit=unit, Type=241, Subtype=7, Switchtype=8 )
    myDev.Create()
    Domoticz.Log('device_create_unit %s/%s  %s created!!!' % (deviceId ,unit, myDev))
def domo_update_witchType_SubType_Type(self, Devices, DeviceID_, Unit_, Type_=0, Subtype_=0, Switchtype_=0):
    Domoticz.Log('domo_update_witchType_SubType_Type  %s/%s %s %s %s' % (DeviceID_ ,Unit_, Type_, Subtype_, Switchtype_))
        Devices[DeviceID_].Units[Unit_].Type = Type_
        Devices[DeviceID_].Units[Unit_].SubType = Subtype_
        Devices[DeviceID_].Units[Unit_].SwitchType = Switchtype_
        Devices[DeviceID_].Units[Unit_].Update(Log=True)
        return
    nValue = Devices[Unit_].nValue
    sValue = Devices[Unit_].sValue
    Devices[Unit_].Update(nValue, sValue, Type=Type_, SubType=Subtype_, SwitchType=Switchtype_)
global _plugin
_plugin = BasePlugin()
def onStart():
    global _plugin
    _plugin.onStart()
def onStop():
    global _plugin
    _plugin.onStop()
def onHeartbeat():
    global _plugin
    _plugin.onHeartbeat()
def onCommand(Unit, Command, Level, Hue):
    global _plugin
    _plugin.onCommand(Unit, Command, Level, Hue)
Logs produced by the plugin. we can see
CSQLHelper::UpdateValueInt: Notifying plugin 13 about creation of device 1
when doing the update !!!
Feb 13 18:52:01 rasp domoticz[18624]: 2024-02-13 18:52:01.367 Update Device: onStart called True
Feb 13 18:52:31 rasp domoticz[18624]: 2024-02-13 18:52:31.079 Update Device: domo_update_witchType_SubType_Type Test Widget/1 244 73 0
Feb 13 18:52:31 rasp domoticz[18624]: 2024-02-13 18:52:31.082 Debug: CSQLHelper::UpdateValueInt: Notifying plugin 13 about creation of device 1
Feb 13 18:53:01 rasp domoticz[18624]: 2024-02-13 18:53:01.087 Update Device: domo_update_witchType_SubType_Type Test Widget/1 241 7 7
Zigbee for Domoticz plugin / RPI3B+ / Electrolama ZZH-P / 45 devices
If the plugin provides you value, you can support me with a donation Paypal.
Wiki is available here.
Zigbee for Domoticz FAQ
pipiche
Re: Extended Python Framework - Updating SwitchType, Type and SubType
Post by pipiche »
