zwave JS-UI newby: extremly slow and lots of messages
Posted: Tuesday 13 February 2024 0:17
by renerene
finally made the jump today and switched from openZwave to Z-wave JS UI, by following
https://www.domoticz.com/wiki/Zwave-JS-UI
Problem: new zwave MQTT devices are very slow, takes several seconds
Also:
2) all devices are refreshed each second in MQTT explorer, leading to a LOT of messages. Screenshot shows status after ca 30 minutes
3) allthough "disable MQTT gateway" is acitvated, messages keep blinking/updating in MQTT Explorer
4) nodeID_xx and the renamed version are both shown in MQTT explorer
5) domoticz log is loaded with 'dicovered' messages
Would be great if someone could help. WAF is an issue at the moment
Re: zwave JS-UI extremly slow and lots of messages
Posted: Tuesday 13 February 2024 0:24
by roblom
Just to be sure; did you press on save on the bottom right of the page?
Posted: Tuesday 13 February 2024 0:54
by renerene
roblom wrote: Tuesday 13 February 2024 0:24
Ah, i did not. Issue 3) is solved
Issue 4) is also solved after reboot.
New information: switch speed is normal (fast) but domoticz status update takes about 3 seconds
Re: zwave JS-UI newby: extremly slow and lots of messages
Posted: Tuesday 13 February 2024 7:11
by renerene
6) DzVents scripts can not switch the new devices.
(and domoticz updates still slow.)
Do i need to use 'store' button under Home Assistant menu?
Posted: Tuesday 13 February 2024 13:36
by mgugu
No, store has only to be used if you change something in Hass Json Device
Posted: Tuesday 13 February 2024 13:46
by mgugu
renerene wrote: Tuesday 13 February 2024 7:11
For some reason, after domoticz is restarted, some devices (not all) are not synchronized (You can check that from domoticz panel). What I do is to activate/desctivate the device from zwave-js-ui panel and then it is OK until the next domoticz restart. Of course retain is set on in zwave panel.
Posted: Tuesday 13 February 2024 14:21
by renerene
mgugu wrote: Tuesday 13 February 2024 13:46
Please tell me more. How can (de)activeate devices?
Are my settings ok?
Posted: Tuesday 13 February 2024 15:10
by mgugu
Go to the device panel, select the non working device, then the non working function. For example for a switch click true/false:
Posted: Tuesday 13 February 2024 16:35
by renerene
mgugu wrote: Tuesday 13 February 2024 15:10
controlling the switches this way works fast and reliable.
In Domoticz however, switch reactions are slow and bad responsive
Posted: Tuesday 13 February 2024 17:13
by BartSr
Since a few days ago I also use ZwaveJs-UI. As I also faced some problems I started a chat with 'the ZwaveJs team'. It appears the ZwaveJs version which comes with docker is very old. Maybe update to newer version might help. I have to investigate how to upgrade. I presume, due to the dockercontainer it's impossible to update from within ZwaveJs-UI.
Posted: Tuesday 13 February 2024 17:39
by waltervl
BartSr wrote: Tuesday 13 February 2024 17:13
Where is your chat with the ZwaveJS team?
Posted: Tuesday 13 February 2024 18:03
by BartSr
I probably used wrong naming.
have a look at issues:
graphic don't show 'neighbour'lines #3599
Don't know how to reproduce an URL
Posted: Tuesday 13 February 2024 19:37
by akamming
i don't understand what you are saying. If you use the instructions on the wiki, you get the latest zwave js ui
anyway: if you used these instruction, the following command will update your docker image to the latest:
docker compose pull (pulls latest docker image)
docker compose down (shutsdown and removes current containter)
docker compose up -d (recreates and starts container on latest docker image)
docker system prune -f (removes old docker image)
Posted: Tuesday 13 February 2024 19:55
by BartSr
Well, for sure I carefully followed the Wiki instructions. But with some help from Linux expert I managed to get latest version.
Posted: Tuesday 13 February 2024 19:57
by waltervl
This is no Linux knowledge but Docker knowledge.....
Posted: Wednesday 14 February 2024 18:57
by BartSr
IMHO you need to know the LINUX commands to control the docker containers.
A Linux-expert was required to get a quick result.
Posted: Thursday 15 February 2024 0:26
by waltervl
Again, Linux has nothing to do with docker. You need docker commands. Docker is just an application you install (on Linux or windows or whatever)
Posted: Thursday 15 February 2024 9:21
by BartSr
Hi Walter,
For me every command to control something from Linux commandline is a LINUX command.
But...
As the commands I used all were like docker blablabla you consider these as docker commands?
In that case I am fully with you.
But my LINUX expert was able to instruct me
For the records how I got the newest ZwaveJS version in docker:
docker-compose stop
docker-compose rm -f
docker-compose pull
docker-composeĀ upĀ -d
But maybe there are more ways to get same result but for me this got me the desired ZwaveJs version.
Actually :
ZwaveJs-UI 9.8.3.3
ZwaveJs 12.4.3
Hopefully we have a bright sky again
Posted: Thursday 15 February 2024 10:28
by waltervl
Yes indeed, those are docker commands.
And dependent on your docker installation it could also be (remove the '-')
docker compose stop
docker compose rm -f
docker compose pull
If you google for 'update docker compose container' you will find a lot of instructions like
https://www.redswitches.com/blog/how-to ... ontainers/
