zwave JS-UI newby: extremly slow and lots of messages
renerene
Post by renerene »
finally made the jump today and switched from openZwave to Z-wave JS UI, by following https://www.domoticz.com/wiki/Zwave-JS-UI
Problem: new zwave MQTT devices are very slow, takes several seconds
Also:
2) all devices are refreshed each second in MQTT explorer, leading to a LOT of messages. Screenshot shows status after ca 30 minutes
3) allthough "disable MQTT gateway" is acitvated, messages keep blinking/updating in MQTT Explorer
4) nodeID_xx and the renamed version are both shown in MQTT explorer
5) domoticz log is loaded with 'dicovered' messages
Would be great if someone could help. WAF is an issue at the moment ;-)
roblom
Re: zwave JS-UI extremly slow and lots of messages
Post by roblom »
Just to be sure; did you press on save on the bottom right of the page?
renerene
Post by renerene »
roblom wrote: Tuesday 13 February 2024 0:24 Just to be sure; did you press on save on the bottom right of the page?
Ah, i did not. Issue 3) is solved
Issue 4) is also solved after reboot.
New information: switch speed is normal (fast) but domoticz status update takes about 3 seconds
renerene
Re: zwave JS-UI newby: extremly slow and lots of messages
Post by renerene »
6) DzVents scripts can not switch the new devices.
(and domoticz updates still slow.)
Do i need to use 'store' button under Home Assistant menu?
mgugu
Post by mgugu »
No, store has only to be used if you change something in Hass Json Device
mgugu
Post by mgugu »
renerene wrote: Tuesday 13 February 2024 7:11 6) DzVents scripts can not switch the new devices.
For some reason, after domoticz is restarted, some devices (not all) are not synchronized (You can check that from domoticz panel). What I do is to activate/desctivate the device from zwave-js-ui panel and then it is OK until the next domoticz restart. Of course retain is set on in zwave panel.
renerene
Post by renerene »
mgugu wrote: Tuesday 13 February 2024 13:46
Please tell me more. How can (de)activeate devices?
Are my settings ok?
mgugu
Post by mgugu »
Go to the device panel, select the non working device, then the non working function. For example for a switch click true/false:
renerene
Post by renerene »
mgugu wrote: Tuesday 13 February 2024 15:10 Go to the device panel, select the non working device, then the non working function. For example for a switch click true/false:
controlling the switches this way works fast and reliable.
In Domoticz however, switch reactions are slow and bad responsive
BartSr
Domoticz version: V2024.7
Post by BartSr »
Since a few days ago I also use ZwaveJs-UI. As I also faced some problems I started a chat with 'the ZwaveJs team'. It appears the ZwaveJs version which comes with docker is very old. Maybe update to newer version might help. I have to investigate how to upgrade. I presume, due to the dockercontainer it's impossible to update from within ZwaveJs-UI.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Domoticz version: 2025.1
BartSr wrote: Tuesday 13 February 2024 17:13 Since a few days ago I also use ZwaveJs-UI. As I also faced some problems I started a chat with 'the ZwaveJs team'. It appears the ZwaveJs version which comes with docker is very old. Maybe update to newer version might help. I have to investigate how to upgrade. I presume, due to the dockercontainer it's impossible to update from within ZwaveJs-UI.
Where is your chat with the ZwaveJS team?
BartSr
Post by BartSr »
I probably used wrong naming.
have a look at issues:
graphic don't show 'neighbour'lines #3599
Don't know how to reproduce an URL
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
akamming
Post by akamming »
i don't understand what you are saying. If you use the instructions on the wiki, you get the latest zwave js ui
anyway: if you used these instruction, the following command will update your docker image to the latest:
docker compose pull (pulls latest docker image)
docker compose down (shutsdown and removes current containter)
docker compose up -d (recreates and starts container on latest docker image)
docker system prune -f (removes old docker image)
BartSr
Post by BartSr »
Well, for sure I carefully followed the Wiki instructions. But with some help from Linux expert I managed to get latest version.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
This is no Linux knowledge but Docker knowledge.....
BartSr
Post by BartSr »
IMHO you need to know the LINUX commands to control the docker containers.
A Linux-expert was required to get a quick result.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Again, Linux has nothing to do with docker. You need docker commands. Docker is just an application you install (on Linux or windows or whatever)
BartSr
Post by BartSr »
Hi Walter,
For me every command to control something from Linux commandline is a LINUX command.
But...
As the commands I used all were like docker blablabla you consider these as docker commands?
In that case I am fully with you.
But my LINUX expert was able to instruct me :-)
For the records how I got the newest ZwaveJS version in docker:
docker-compose stop
docker-compose rm -f
docker-compose pull
docker-compose up -d
But maybe there are more ways to get same result but for me this got me the desired ZwaveJs version.
Actually :
ZwaveJs-UI 9.8.3.3
ZwaveJs 12.4.3
Hopefully we have a bright sky again :-)
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Yes indeed, those are docker commands.
And dependent on your docker installation it could also be (remove the '-')
docker compose stop
docker compose rm -f
docker compose pull
If you google for 'update docker compose container' you will find a lot of instructions like https://www.redswitches.com/blog/how-to ... ontainers/
