Problem with SNZB-02 sensor in Zigbee4Domoticz
Posted: Friday 09 February 2024 10:19
by ophenix
After upgrading from version stable6-6.3.010 to the latest 7.1.008 (2024.1), the SNZB-02 sensor
https://zigbee.blakadder.com/Sonoff_SNZB-02.html no longer functions correctly. While pairing the sensor is successful, the plugin no longer captures temperature and humidity readings. Does anyone have any idea what the problem might be?
The system is an Raspberry Pi 2 (Bullseye) and the latest version of Domoticz.
Re: Problem with SNZB-02 sensor in Zigbee4Domoticz
Posted: Friday 09 February 2024 10:35
by waltervl
I see with this device that you completely have to remove it from the system to re-pair it.
So remove all related devices from Domoticz (temp, hum, Temp+Hum) then go to Zigbee4Domoticz UI (port 9440) and go to devices and see if the device is still there. If there delete it.
When successfully deleted you can re-pair it with the stick and values are updated.
Posted: Friday 09 February 2024 10:48
by ophenix
I have tried deleting and then re-pairing the sensor many times, but the result remains the same, the plugin does not receive values from the sensor. Other devices, such as smart lamps, work without any issues.
I have also tried pairing the sensor with another zigbee system, where it works flawlessly, leading me to believe the problem does not lie with the sensor.
Posted: Friday 09 February 2024 11:11
by waltervl
Did you check if the device is completely deleted from Zigbee4Domoticz (not only Domoticz) before re-pairing it?
Posted: Friday 09 February 2024 11:13
by ophenix
Yes, this is correct. The Device is complete removed both from Zigbee4Domoticz and Domoticz
Posted: Friday 09 February 2024 11:22
by waltervl
Then you probably have to share you pairing logging.....
Or create an issue on the Zigbee4Domoticz repository
But wait for @pipiche
Posted: Saturday 10 February 2024 15:48
by pipiche
as usall could you please provide some data ?
- plugin logs
- domoticz logs
- export.json ( Plugin Device Raw)
Posted: Saturday 10 February 2024 15:56
by habahabahaba
Plugin: 7.1.008
Dz 2024.4
It working correctly
Posted: Tuesday 13 February 2024 8:48
by ophenix
Sorry for the late reply, here is the logs.
