After upgrading from version stable6-6.3.010 to the latest 7.1.008 (2024.1), the SNZB-02 sensor https://zigbee.blakadder.com/Sonoff_SNZB-02.html no longer functions correctly. While pairing the sensor is successful, the plugin no longer captures temperature and humidity readings. Does anyone have any idea what the problem might be?
The system is an Raspberry Pi 2 (Bullseye) and the latest version of Domoticz.
Problem with SNZB-02 sensor in Zigbee4Domoticz
- Domoticz version: 2025.1
Re: Problem with SNZB-02 sensor in Zigbee4Domoticz
I see with this device that you completely have to remove it from the system to re-pair it.
So remove all related devices from Domoticz (temp, hum, Temp+Hum) then go to Zigbee4Domoticz UI (port 9440) and go to devices and see if the device is still there. If there delete it.
When successfully deleted you can re-pair it with the stick and values are updated.
ophenix
I have tried deleting and then re-pairing the sensor many times, but the result remains the same, the plugin does not receive values from the sensor. Other devices, such as smart lamps, work without any issues.
I have also tried pairing the sensor with another zigbee system, where it works flawlessly, leading me to believe the problem does not lie with the sensor.
Did you check if the device is completely deleted from Zigbee4Domoticz (not only Domoticz) before re-pairing it?
ophenix
Yes, this is correct. The Device is complete removed both from Zigbee4Domoticz and Domoticz
Then you probably have to share you pairing logging.....
Or create an issue on the Zigbee4Domoticz repository
But wait for @pipiche
as usall could you please provide some data ?
- plugin logs
- domoticz logs
- export.json ( Plugin Device Raw)
- plugin logs
- domoticz logs
- habahabahaba
- Domoticz version: 2024.4
Plugin: 7.1.008
Dz 2024.4
It working correctly
Dz 2024.4
ophenix
Sorry for the late reply, here is the logs.
- plugin_log.txt
- (29.61 KiB) Downloaded 29 times
- export_json.txt
- (7.84 KiB) Downloaded 30 times
- domoticz_log.txt
- (2.6 KiB) Downloaded 24 times
