Install zwave-js-ui
Posted: Monday 05 February 2024 15:46
by pkelderman
I am trying to install docker and zwave-js-ui now. Confirm the instruction in "
https://www.domoticz.com/wiki/Zwave-JS-UI" I have to
edit (=change an existing) file "docker-compose.yml". I can't find that file. Should I
create that (and where) or should I edit another file? Someone any idea?
Re: Install zwave-js-ui
Posted: Monday 05 February 2024 16:38
Like for every docker (see eg mosquitto) you have to do in the root folder of the container. Probably /opt/zwavejs-ui
Posted: Monday 05 February 2024 16:52
by jannl
An example is also in the docker section of Zwave ui on github. That is basically the one I use/downloaded.
Below the onde from github.
Version: '3.7'
services:
zwave-js-ui:
container_name: zwave-js-ui
image: zwavejs/zwave-js-ui:latest
restart: always
tty: true
stop_signal: SIGINT
environment:
- SESSION_SECRET=mysupersecretkey
- ZWAVEJS_EXTERNAL_CONFIG=/usr/src/app/store/.config-db
# Uncomment if you want logs time and dates to match your timezone instead of UTC
# Available at https://en.wikipedia.org/wiki/List_of_tz_database_time_zones
#- TZ=America/New_York
networks:
- zwave
devices:
# Do not use /dev/ttyUSBX serial devices, as those mappings can change over time.
# Instead, use the /dev/serial/by-id/X serial device for your Z-Wave stick.
- '/dev/serial/by-id/insert_stick_reference_here:/dev/zwave'
volumes:
- zwave-config:/usr/src/app/store
ports:
- '8091:8091' # port for web interface
- '3000:3000' # port for Z-Wave JS websocket server
networks:
zwave:
volumes:
zwave-config:
Posted: Thursday 15 February 2024 16:23
by pkelderman
Surprise, surprise. It doesnot work again. Using a "spare" raspberry 3b+ I installing Raspbian OS, Domoticz (2024.4) and docker, mosquitto and zwave-js-ui. I was hopefull after the /opt/mosquitto location of the docker-mosquitto.y4ml file. But unfortunately. The end of the story remains an empty configuration table in te setup page of mqtt in domoticz hardware. Resulting: no devices.
- afbeelding_2024-02-15_162229882.png (56.09 KiB) Viewed 2097 times
Please: help, help, help.
Posted: Thursday 15 February 2024 16:47
Surprise surprise, you are looking in the wrong location!!!!!
https://www.domoticz.com/wiki/Zwave-JS- ... nt_gateway
After adding/updating the MQTT Client Gateway for Zwave-JS-UI the Zwave devices will be automatically added in the Domoticz device list if discovered by Zwave-JS-UI, check menu Setup - Devices. Domoticz devices will be created once data is received. So especially for battery operated devices it can take some time to have this data received. Sometimes it is possible to activate these sensors manually by pushing a button.
Hint: To add all devices at once, press "Save" in Zwave-JS-UI preferences. This will generate status messages for all devices. Or restart Zwave-JS-UI.
Posted: Thursday 15 February 2024 17:22
I have modified the Zwave-JS-UI wiki to make extra clear that the setup button of MQTT AD Hardware is used for something different then in the old OZW integration.
Note: In contrary to the old OpenZwave integration the devices/switches will not be shown in the Setup button of the MQTT Hardware Gateway but in the main Domoticz device list ( menu Setup -Devices)! Zwave Nodes etc will be managed from Zwave-JS-UI user interface on port 8091, not in Domoticz.
Note: After creation of the MQTT Autodiscover hardware in menu Setup - Hardware you can click on the setup button to configure the discovered configuration devices if they have that option using Autodiscovery Number devices. It could well be that this list is completely empty! It is used for setting preference of devices, eg detection distance, Connection interval, LED brightness etc.
Posted: Sunday 18 February 2024 14:42
by pkelderman
Reading the instruction better I should find my z-wave devices under devices and not under hardware. As far as I understand I should find them here:
- afbeelding_2024-02-18_143943400.png (38.03 KiB) Viewed 2043 times
Where am I wrong this time? Mind: I made a new installation and no conversion of the old open zwave.
I managed to introduce zwave-js-ui as a custom menu item:
- afbeelding_2024-02-18_150503400.png (76.89 KiB) Viewed 2041 times
Posted: Sunday 18 February 2024 16:25
by BartSr
Did you set MQTT to correct IP in ZwaveJS- UI (not localhost).
Did you add MQTT AD in your hardware?
Posted: Thursday 22 February 2024 16:38
by pkelderman
I have checked, checked, dubble checked the ip-adresses. As far as i can see, they are all correct. I will ask more questions the next days, because i have doubts about the configuration in zwave-js-ui.
Posted: Thursday 22 February 2024 17:49
Check with the application MQTT Explorer (can be installed on any system in your network) if you have the topics as explained in the MQTT_AD_Report_Problems wiki, do you have a zwave and a homeassistant topic with subtopics in MQTT explorer? See also the example screenshot (showing combined zwavejsui and zigbee2mqtt topics) in the wiki:
https://www.domoticz.com/wiki/MQTT_AD_Report_Problems
Also share your Domoticz MQTT AD configuration.
