Strange entry in my logfile
Posted: Monday 05 February 2024 13:14
by costo
I have my Domoticz run on a raspberry pi 3B.
On my Fritz!Box router I have made my raspberry accessable from the internet. I sometimes see messages like this in the logfile:
2024-02-04 19:23:21.793 Error: Error parsing http request address: ::ffff:172.233.57.39
but not so much that I worry about these attempts.
I have changed the 8080 port externally to a different high number port, all in IPv4
Ofcourse access to the Pi and to domoticz is protected with a password.
But this morning I found a strange entry in my logfile:
2024-02-05 07:55:02.172 subtype = Interface Command
2024-02-05 07:55:02.172 Sequence nbr = 47
2024-02-05 07:55:02.172 Status: Incoming Domoticz connection from: 194.165.16.73
It looks like this IP got access to the Raspberry Pi or domoticz ?
I have no idea what the messages subtype and nbr mean.
Can someone enlighten me what could be going on here ?
Re: Strange entry in my logfile
Posted: Thursday 08 February 2024 10:21
by Daik
194.165.16.73 is a local network Ip adress. Are you sure that it does not come from one of your devices?
Posted: Thursday 08 February 2024 10:28
by lost
Daik wrote: Thursday 08 February 2024 10:21
That's not correct, this IP is not in one of the private IPv4 range.
returns an IP allocated to
role: FLYSERVERS GLOBAL NETWORK OPERATION CENTRE
address: 50th Street, Global Bank Tower, Suite 1801
address: Panama
Posted: Thursday 08 February 2024 10:35
by lost
costo wrote: Monday 05 February 2024 13:14
Opening http to the outside/WAN, that's kind of playing russian roulette with 5 bullets in the barrel: That's all un-ciphered including password.
=> Open https, but you'll need a domain (no-ip provides free ones) if not already done for your http WAN use + certificate (let's encrypt, as self-signed like Domoticz default one are more & more refused by browsers no more allowing such exceptions). And meantime remove your redirection & change password! Also check carefully if you don't have suspect processes/behavior on the host running domoticz.
Posted: Thursday 08 February 2024 11:18
IP 172.233.57.39 could be an internal Docker IP. Is Domoticz running in a docker environment?
Posted: Thursday 08 February 2024 11:32
by Tukker
I don't think so.
- Local IP.jpg (30.15 KiB) Viewed 1785 times
My personal solution is having the RPI solely local and connect from outside using Wireguard (
PiVPN)
Wireguard establishes a tunnel where no-one can snoop or interfere.
Posted: Thursday 08 February 2024 18:43
by costo
waltervl wrote: Thursday 08 February 2024 11:18
Nope , Domoticz runs on a Raspi3B with only Domoticz installed
Posted: Thursday 08 February 2024 18:55
by costo
lost wrote: Thursday 08 February 2024 10:35
Nothing essential running on Domoticz or the RasPi. It runs like this for several years so I can monitor my system (and home) when I'm away.
I was just wondering what these things mean:
Sequence nbr = 4
It looks like these were launched from the unknown IP address.
Posted: Thursday 08 February 2024 18:56
by Kedi
You are just 1 step away from being compromized.
If the next line reads:
Status: Login successful from x.x.x.x for user 'YYYY'
The that guy (or women) is in.
Posted: Monday 12 February 2024 11:16
by lost
costo wrote: Thursday 08 February 2024 18:55
Nothing essential, but you have the possibility to allow a secure remote access. The PI in in your lan so may be used to bounce/compromise other elements... Or just doing bad things that will appear coming from you at 1st sight & may bring police early one morning, behaving like wild boars in your home until they understand you're not the guilty one (IMO, for such problem, this'll take time & turn to a... very bad time for you & relatives).
If you want to better know what theses messages are for, as I don't see them on my secured setup, that's open source so a white box: Upload the source (preferably the version you use), do a recursive grep on some invariant part of the message/without what may be added by logger or any variable element and read the code around to know if this may be an issue or not (for now).
