Dashticz: show current power kWh?
Posted: Sunday 04 February 2024 9:35
by renerene
How to create a large text fiels showing current power consumption / delivery?
Two problems, one nicetohave:
1) code below show 8 devices, I'm only interested in the first one (current/actual)
blocks['kWh'] = {
idx: 427, //The Domoticz device id
title: 'kWh', //The title of the block as shown in the dial.
width: 6, //The width of the block relative to the column width
2) making the font bigger in CSS does not adjust the background, the big font floats over the small background rectangle
custom.css:
.block_kWh {
font-size:120px !important;
3) an alarm clock font would be nice
Re: Dashticz: show current power kWh?
Posted: Monday 05 February 2024 14:27
by EdwinK
Try with idx: '427_1' to get only the first device.
Posted: Monday 05 February 2024 18:55
by renerene
EdwinK wrote: Monday 05 February 2024 14:27
No, that does not work. Here is the result:
Posted: Monday 05 February 2024 19:08
by HansieNL
Can you post your blockcode. Did you exactly use the idx: '427_1' ?
Posted: Monday 05 February 2024 19:22
by renerene
HansieNL wrote: Monday 05 February 2024 19:08
'427_1' ?
this was my code;
blocks['kWh'] = {
idx: 427_1, //The Domoticz device id
but after changing to code below, it works. Thanks!
blocks['kWh'] = {
idx: '427_1', //The Domoticz device id
only issue left is ugly layout. Text is placed to low, background rectangle does not resize with font size
Posted: Tuesday 06 February 2024 21:59
by Lokonli
By default the height of each Domoticz device block is fixed at a certain value (85 pixels to be precise)
You can make the height adjust to the content by using the following in custom.css:
.block_kWh {
font-size: 120px;
height: unset!important
Posted: Wednesday 07 February 2024 7:59
by renerene
thanks!
Got it working now:
.block_kWh {
font-size:80px !important;
blocks['kWh'] = {
hide_title: true,
unit: ' Watt',
