Dashticz: show current power kWh?
renerene
Post by renerene »
How to create a large text fiels showing current power consumption / delivery?
Two problems, one nicetohave:
1) code below show 8 devices, I'm only interested in the first one (current/actual)
blocks['kWh'] = {
  idx: 427,                   //The Domoticz device id
  title: 'kWh',       //The title of the block as shown in the dial.
  width: 6,                   //The width of the block relative to the column width
2) making the font bigger in CSS does not adjust the background, the big font floats over the small background rectangle
custom.css:
.block_kWh {
   font-size:120px !important;
3) an alarm clock font would be nice
EdwinK
Re: Dashticz: show current power kWh?
Post by EdwinK »
Try with idx: '427_1' to get only the first device.
renerene
Post by renerene »
EdwinK wrote: Monday 05 February 2024 14:27 Try with idx: '427_1' to get only the first device.
No, that does not work. Here is the result:
HansieNL
Post by HansieNL »
Can you post your blockcode. Did you exactly use the idx: '427_1' ?
Blah blah blah
renerene
Post by renerene »
HansieNL wrote: Monday 05 February 2024 19:08 Can you post your blockcode. Did you exactly use the idx: '427_1' ?
this was my code;
blocks['kWh'] = {
  idx: 427_1,                   //The Domoticz device id
but after changing to code below, it works. Thanks!
blocks['kWh'] = {
  idx: '427_1',                   //The Domoticz device id
only issue left is ugly layout. Text is placed to low, background rectangle does not resize with font size
Lokonli
Post by Lokonli »
By default the height of each Domoticz device block is fixed at a certain value (85 pixels to be precise)
You can make the height adjust to the content by using the following in custom.css:
 .block_kWh {
    font-size: 120px;
    height: unset!important
renerene
Post by renerene »
thanks!
Got it working now:
.block_kWh {
   font-size:80px !important;
blocks['kWh'] = {
  hide_title: true,
  unit: ' Watt',
