Today I finally tried in a test environment Zwave-JS-UI.
Possibly due to testing I made an error I cannot trace.
I tried with powerplug. Finally it was working as expected but every time a 2nd switch device belonging to the powerplug was created while that one failed switching on/off the powerplug.
I know it has something to do with a retain-setting but can t find it. I remember to have seen posts about.
Any suggestion how to stop creating this device.
TIA
Bart
MQTT - Zwave-JS-UI possible retain problem Topic is solved
BartSr
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- Domoticz version: 2026.3
Re: MQTT - Zwave-JS-UI possible retain problem
You have to remove the related retained discovery topic with mqtt-explorer (or other mqtt publishing tool). See https://www.domoticz.com/wiki/MQTT#Dele ... ined_topic
The discovery topics are default in the mqtt homeassistant folder if you did not change the discovery topic prefix in Zwave-JS-UI.
BartSr
Dank Walter. Probleem opgelost.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
