Help with os.execute in lua script
Posted: Sunday 28 January 2024 16:16
by Kjakan
This command work for me in command line:
curl -X POST -H "Content-Type: application/json" -d '{"text": "Test Message"}' http://192.168.2.34/api/notify
How can I get this command to run in lua?
This does not work.
os.execute ('curl -X POST -H "Content-Type: application/json" -d '{"text": "Test Message"}' http://192.168.2.34/api/notify')
/lua/script_variable_Timelapse.lua:15: ')' expected near '{'
I'm guessing I need to escape some characters, but not sure how.
Domoticz 2024.2 and Debian bookworm
Re: Help with os.execute in lua script
Posted: Sunday 28 January 2024 18:36
by habahabahaba
Try
os.execute('curl -X POST -H "Content-Type: application/json" -d \'{\"text\": \"Test Message\"}\' http://192.168.2.34/api/notify')
Posted: Sunday 28 January 2024 20:02
by Kjakan
Thanks for the response. No error in domoticz, but command did not execute.
I've tried different ways, but I may be missing something.
Posted: Sunday 28 January 2024 20:25
by Kedi
try:
os.execute('curl -X POST -H "Content-Type: application/json" -d \"{\"text\": \"Test Message\"}\" http://192.168.2.34/api/notify')
or
os.execute('curl -X POST -H "Content-Type: application/json" -d "{\"text\": \"Test Message\"}" http://192.168.2.34/api/notify')
Posted: Sunday 28 January 2024 20:31
by habahabahaba
what OS you are using?
Posted: Sunday 28 January 2024 20:35
by Kjakan
Debian bookworm.
Still no luck. No error in domoticz and command not execute.
If I change -d '{\"text\": \"Test Message\"}' to -d "{\"text\": \"Test Message\"}" the command will not work and no error in domoticz,
Posted: Sunday 28 January 2024 21:26
by Kjakan
This works in command line, but not in lua. No error in domotiicz, but command not execute.
Any other easy way to send json to http api in lua?
Posted: Sunday 28 January 2024 21:33
by jvdz
What about this version
os.execute('curl -X POST -H "Content-Type: application/json" -d \'{"text": "Test Message"}\' http://192.168.2.34/api/notify')
Posted: Sunday 28 January 2024 21:38
by Kjakan
Same result. No error in domoticz, but command not execute.
From command line
curl: (3) unmatched close brace/bracket in URL position 13:
Test Message}'
Posted: Sunday 28 January 2024 22:29
by Kjakan
habahabahaba wrote: Sunday 28 January 2024 18:36
Try
This is working. I messed up somwhere
Thanks for the help.
Posted: Monday 29 January 2024 5:24
by habahabahaba
And may be it is better to use domoticz.executeShellCommand ?
Wiki
Posted: Monday 29 January 2024 7:46
by akamming
Or domoticz.openURL?
Posted: Monday 29 January 2024 21:31
by Kjakan
I take a look at this. Thanks.
