Help with os.execute in lua script
Kjakan
Domoticz version: 2024.2
Post by Kjakan »
This command work for me in command line:
curl -X POST -H "Content-Type: application/json" -d '{"text": "Test Message"}' http://192.168.2.34/api/notify
How can I get this command to run in lua?
This does not work.
os.execute ('curl -X POST -H "Content-Type: application/json" -d '{"text": "Test Message"}' http://192.168.2.34/api/notify')
/lua/script_variable_Timelapse.lua:15: ')' expected near '{'
I'm guessing I need to escape some characters, but not sure how.
Domoticz 2024.2 and Debian bookworm
habahabahaba
Domoticz version: 2024.4
Re: Help with os.execute in lua script
Post by habahabahaba »
Try
os.execute('curl -X POST -H "Content-Type: application/json" -d \'{\"text\": \"Test Message\"}\' http://192.168.2.34/api/notify')
Kjakan
Post by Kjakan »
Thanks for the response. No error in domoticz, but command did not execute.
I've tried different ways, but I may be missing something.
Kedi
Domoticz version: latest
Post by Kedi »
try:
os.execute('curl -X POST -H "Content-Type: application/json" -d \"{\"text\": \"Test Message\"}\" http://192.168.2.34/api/notify')
or
os.execute('curl -X POST -H "Content-Type: application/json" -d "{\"text\": \"Test Message\"}" http://192.168.2.34/api/notify')
habahabahaba
what OS you are using?
Kjakan
Post by Kjakan »
Debian bookworm.
Still no luck. No error in domoticz and command not execute.
If I change -d '{\"text\": \"Test Message\"}' to -d "{\"text\": \"Test Message\"}" the command will not work and no error in domoticz,
Kjakan
Post by Kjakan »
This works in command line, but not in lua. No error in domotiicz, but command not execute.
Any other easy way to send json to http api in lua?
jvdz
Domoticz version: 4.107
Post by jvdz »
What about this version
os.execute('curl -X POST -H "Content-Type: application/json" -d \'{"text": "Test Message"}\' http://192.168.2.34/api/notify')
Kjakan
Post by Kjakan »
Same result. No error in domoticz, but command not execute. :?
From command line
curl: (3) unmatched close brace/bracket in URL position 13:
Test Message}'
Kjakan
Post by Kjakan »
habahabahaba wrote: Sunday 28 January 2024 18:36 Try
This is working. I messed up somwhere :oops:
Thanks for the help.
habahabahaba
And may be it is better to use domoticz.executeShellCommand ?
Wiki
akamming
Post by akamming »
Or domoticz.openURL?
Kjakan
Post by Kjakan »
I take a look at this. Thanks.
