zigbee2MQTT Error
rolandtwilt
zigbee2MQTT Error
Post by rolandtwilt »
Sorry for my bad English. Who can help me with the following problem?
after the last update i'm getting a lot of glitches and half of my devices are offline and can't be added again after i delete them. I get the following er message after: sudo service zigbee2mqtt status
● zigbee2mqtt.service - zigbee2mqtt
Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; vendor pres
Active: failed (Result: exit-code) since Fri 2024-01-26 18:19:02 CET; 19min a
Process: 506 ExecStart=/usr/bin/sudo /usr/bin/node index.js (code=exited, stat
Main PID: 506 (code=exited, status=1/FAILURE)
jan 26 18:17:53 raspberrypi sudo[506]: Zigbee2MQTT:warn 2024-01-26 18:17:53: Fa
jan 26 18:18:50 raspberrypi systemd[1]: Stopping zigbee2mqtt...
jan 26 18:18:50 raspberrypi sudo[506]: Zigbee2MQTT:info 2024-01-26 18:18:50: MQ
jan 26 18:18:50 raspberrypi sudo[506]: Zigbee2MQTT:info 2024-01-26 18:18:50: Di
jan 26 18:18:50 raspberrypi sudo[506]: Zigbee2MQTT:info 2024-01-26 18:18:50: St
jan 26 18:19:02 raspberrypi sudo[506]: Zigbee2MQTT:error 2024-01-26 18:19:02: Fa
jan 26 18:19:02 raspberrypi sudo[506]: pam_unix(sudo:session): session closed fo
jan 26 18:19:02 raspberrypi systemd[1]: zigbee2mqtt.service: Main process exited
jan 26 18:19:02 raspberrypi systemd[1]: zigbee2mqtt.service: Failed with result
jan 26 18:19:02 raspberrypi systemd[1]: Stopped zigbee2mqtt.
solarboy
Domoticz version: 2024.6
Re: zigbee2MQTT Error
Post by solarboy »
This looks like a zigbee2mqtt error and not Domoticz. You might try their forums.
gizmocuz
Post by gizmocuz »
Better to use zigbee2mqtt in a docker compose environment... Than you know it is working, and keeps working.
https://www.domoticz.com/wiki/Zigbee2MQTT
