Settings Aeotec Z-stick under MQTT / JS-UI Topic is solved
studiocascade
Post by studiocascade »
Recently i successfully migrated from Open ZWave to ZWave-JS-UI via Docker.
My Domoticz version is 2024.2
Everything is working fine, but there are two things unclear to me
  1. Where can i find the settings of my Aeotec Z-stick Gen 5?
  2. The Settings-button under the hardware "MQTT" leads to an empty 'list'. Is there a way to activate settings there?
Thanks for your reply,
Sincerely,
Johan
Domoticz version: 2025.1
Re: Settings Aeotec Z-stick under MQTT / JS-UI
Setting for zwave are in the Zwave-JS-UI interface. Not in Domoticz.
In the setup button there are only the zwave devices that publish configuration topics, eg resolution, or accuracy. Most devices do not publish these so the list will be empty.
studiocascade
Thanks for your quick reply!
I can find settings to all my zwave devices in the JS-UI interface, except for the settings of the Aeotec Z-stick.
There's a a led blinking on this device and i would like to turn it off.
In OZW i could easily find the settings for my Z-stick.
Do you know where i should be able find that in the JS-UI interface?
I have no clue, you better ask this in the Zwave-JS-UI forum. If not available they can perhaps implement this option. https://github.com/zwave-js/zwave-js-ui/discussions
bvdf0251
Post by bvdf0251 »
echo -e -n "\x01\x08\x00\xF2\x51\x01\x00\x05\x01\x51" > /dev/serial/by-id/usb-0658_0200-if00
In terminal.
You can also make a script of it and assign it to a dummy switch.
That's what I did.
nano ZstickLedOff.sh
#!/bin/bash
Save in scripts dir
studiocascade
Thanks a lot! i'll run the first command. No need for a dummy switch (yet)
BartSr
Domoticz version: V2024.7
Post by BartSr »
use docker compose? In that case what was your update of the yaml file to meet stick interface?
I m stuck on this.
Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
