enter data into domoticz fails
Posted: Monday 22 January 2024 14:33
Please help.
Upgraded to PI OS bookworm and to a PI4
after this my python script does not work anymore. I worked before perfect.
I use:
Normally I got a response from Domoticz that the the call was accepted.
But now not response nor fault message
Jumped back to BUSTER. Same problem
thanks so far, Willem
I use:
temp = "10.0"
command = 'curl -s \"http://192.168.2.100:8080/json.htm?type=command¶m=udevice&idx=13&nvalue=0&svalue=TEMP\"'
command = command.replace("TEMP",temp)
os.system(command)But now not response nor fault message
