enter data into domoticz fails
willem9136
Post by willem9136 »
Please help.
Upgraded to PI OS bookworm and to a PI4
after this my python script does not work anymore. I worked before perfect.
I use:
temp = "10.0"
command = 'curl -s \"http://192.168.2.100:8080/json.htm?type=command&param=udevice&idx=13&nvalue=0&svalue=TEMP\"'
command = command.replace("TEMP",temp)
os.system(command)
Normally I got a response from Domoticz that the the call was accepted.
But now not response nor fault message
Jumped back to BUSTER. Same problem
thanks so far, Willem
Domoticz version: 2025.1
Re: enter data into domoticz fails
Did you also update Domoticz to a new version as there were some security changes..
For example you need to set Allow basic auth for HTTP in menu setup - settings, tab security when using http
