how can i get the value of a timer into a variable?
bitzy
Domoticz version: 2023.2
Post by bitzy »
english is not primary language so i'm sure the title is not suggestive and the explanation will be a struggle :D
i want to take the value that i set for a timer into a variable inside the script, something like:
timer = { 'every x minutes' }
local dt = time_Of_The_Timer -- (x).
i know i can do this manually when i set the value of the timer (but i'm kinda lazy) so i want this to be done automatically when i change 'x', in case i forget to change dt also. is there a way to do this?
Re: how can i get the value of a timer into a variable?
You could do it the other way around:
timer = { 'every dt minutes' }
willemd
Post by willemd »
Or you could take the second value after you split the trigger into words, as shown in the example dzVents script below
		timer = {
			'every 2 minutes',
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'template',
	execute = function(domoticz, timer)
		domoticz.log('Timer event was triggered by ' .. timer.trigger, domoticz.LOG_INFO)
		local deltaT=domoticz.utils.stringSplit(timer.trigger," ")[2]
		domoticz.log("deltaT="..deltaT, domoticz.LOG_INFO)
Kedi
Domoticz version: latest
Post by Kedi »
waltervl wrote: Sunday 21 January 2024 18:28 You could do it the other way around:
Sorry @waltervl that does not work, this works:
local dt = 2
        timer = {
            'every '..tostring(dt)..' minutes',
And sorry @willemd I think it is the better solution: does not involve further programming.
Tukker
Post by Tukker »
Or use
local current_time =  os.date("%c")
and
local subject = 'My time in a string. '
                    local message =
                    ' ' .. current_time .. '\n'..
                    'Succeede ! \n'
                    domoticz.notify(subject, message, domoticz.PRIORITY_NORMAL)
Where current_time is your string.
Formatting the output of os.date() is explained over here.
Bugs bug me.
bitzy
Post by bitzy »
was so easy, i feel a little bit ashamed now :oops: :D
for me worked:
dt = 2
timer = {'every '..dt..' minutes'} and also the Kedi's version.
the local dt=domoticz.utils.stringSplit(timer.trigger," ")[2] don't work for me. i get an error related to the use of 'timer.trigger' - attempt to index a nil value 'timer'
thanks for the answears.
willemd
Post by willemd »
It does not work because you probably don't have execute=function(domoticz,timer) in your script but something else for example "item" instead of "timer".
If you use "item" then you should also use "item.trigger". It has to match.
bitzy
Post by bitzy »
willemd wrote: Tuesday 23 January 2024 9:50 It does not work because you probably don't have execute=function(domoticz,timer) in your script but something else for example "item" instead of "timer".
u are right :D. is working now
