Install files save script (Linux)
Posted: Tuesday 16 January 2024 16:04
For those that may want to save Domoticz stable/beta install files, as experience proves this may be useful as builds are not kept (most probably because this would need huge storage & have a cost), here is my small bash scripts that saves current install archives locally:
Save this as get_dz_installs.sh for instance then make it executable using:
and call it with either "s" (stable) or "b" (beta) parameter from directory where file was saved:
This'll build a dated release directory with all supported archs/os install files inside, for instance:
So, if needed, the file for your system/machine may be extracted as done by upgrade scripts. Take care that downgrade may cause DB version issues, so always better to save whole current domoticz tree before any version change attempt...
#!/bin/bash
# Scripts that'll download all Domoticz install files for current stable or beta release.
# Editable settings, if base download URL or supported OS/ARCH change someday...
# Base URL can be checked in domoticz/update[beta|release].sh scripts.
DZ_DNLD_URL='https://www.domoticz.com/download.php?'
SYSTEMS='linux windows'
MACHINES='aarch64 armv7l x86_64 x86'
error()
echo $1
exit 1
usage()
echo "Usage : $0 [b|s] ; Download all Domoticz beta/stable install archives..."
exit 0
# Non foolproof args check:
[ $# -ne 1 ] && usage
case $1 in
b | B) channel='beta';;
s | S) channel='stable';;
echo "Try better next time !"
usage;;
esac
# Create install archives save directory:
today=$(date +"%y%m%d")
dirTd=$channel'_'$today
mkdir $dirTd || error "Could not make directory : $dirTd"
echo "Getting files for $channel/$today -> $dirTd/ ..."
# Download channel archives for all machine/system combinations:
for machine in $MACHINES
do
for system in $SYSTEMS
do
dz_url="${DZ_DNLD_URL}channel=${channel}&type=release&system=${system}&machine=${machine}"
#echo "Download ${system}/${machine} from ${dz_url}..."
wget -4 -q -O $dirTd/domoticz_${channel}_${system}_${machine}.tgz --no-check-certificate ${dz_url}
[ $? -ne 0 ] && echo "No $channel file for ${system}/${machine}..." || echo "Done, ${channel} for ${system}/${machine} !"
done
done
# Remove zero-sized files that may result from non supported machine/system combinations...
find $dirTd -maxdepth 1 -size 0c -delete
echo "That's All Folks!!!"
exit 0
chmod +x get_dz_installs.shCode: Select all
./get_dz_installs.sh s
(or)
$ tree stable_240116/
stable_240116/
├── domoticz_stable_linux_aarch64.tgz
├── domoticz_stable_linux_armv7l.tgz
├── domoticz_stable_linux_x86_64.tgz
└── domoticz_stable_windows_x86.tgz
