Install files save script (Linux)
All kinds of 'OS' scripts
lost
Post by lost »
For those that may want to save Domoticz stable/beta install files, as experience proves this may be useful as builds are not kept (most probably because this would need huge storage & have a cost), here is my small bash scripts that saves current install archives locally:
#!/bin/bash
# Scripts that'll download all Domoticz install files for current stable or beta release.
# Editable settings, if base download URL or supported OS/ARCH change someday...
# Base URL can be checked in domoticz/update[beta|release].sh scripts.
DZ_DNLD_URL='https://www.domoticz.com/download.php?'
SYSTEMS='linux windows'
MACHINES='aarch64 armv7l x86_64 x86'
error()
 echo $1
 exit 1
usage()
  echo "Usage : $0 [b|s] ; Download all Domoticz beta/stable install archives..."
  exit 0
# Non foolproof args check:
[ $# -ne 1 ] && usage
case $1 in
  b | B) channel='beta';;
  s | S) channel='stable';;
    echo "Try better next time !"
    usage;;
esac
# Create install archives save directory:
today=$(date +"%y%m%d")
dirTd=$channel'_'$today
mkdir $dirTd || error "Could not make directory : $dirTd"
echo "Getting files for $channel/$today -> $dirTd/ ..."
# Download channel archives for all machine/system combinations:
for machine in $MACHINES
do
  for system in $SYSTEMS
  do
    dz_url="${DZ_DNLD_URL}channel=${channel}&type=release&system=${system}&machine=${machine}"
    #echo "Download ${system}/${machine} from ${dz_url}..."
    wget -4 -q -O $dirTd/domoticz_${channel}_${system}_${machine}.tgz --no-check-certificate ${dz_url}
    [ $? -ne 0 ] && echo "No $channel file for ${system}/${machine}..." || echo "Done, ${channel} for ${system}/${machine} !"
  done
done
# Remove zero-sized files that may result from non supported machine/system combinations...
find $dirTd -maxdepth 1 -size 0c -delete
echo "That's All Folks!!!"
exit 0
Save this as get_dz_installs.sh for instance then make it executable using:
chmod +x get_dz_installs.sh
and call it with either "s" (stable) or "b" (beta) parameter from directory where file was saved:
./get_dz_installs.sh s
(or)
This'll build a dated release directory with all supported archs/os install files inside, for instance:
$ tree stable_240116/
stable_240116/
├── domoticz_stable_linux_aarch64.tgz
├── domoticz_stable_linux_armv7l.tgz
├── domoticz_stable_linux_x86_64.tgz
└── domoticz_stable_windows_x86.tgz
So, if needed, the file for your system/machine may be extracted as done by upgrade scripts. Take care that downgrade may cause DB version issues, so always better to save whole current domoticz tree before any version change attempt...
Re: Install files save script (Linux)
Builds are being kept for major releases in the GitHub repository. Eg https://github.com/domoticz/domoticz/re ... tag/2024.2
Kedi
Domoticz version: latest
Post by Kedi »
Why would you save tgz files of systems that you don't have.
Beside the update script saves all in the domoticz dir into a tgz file in the backup dir.
lost
Post by lost »
Kedi wrote: Tuesday 16 January 2024 19:30 Why would you save tgz files of systems that you don't have.
Answer was in the post that was pointing to this one in the 2024.2 topic that is no more there (send failed?)!
Raspberries are almost always out of stock, so in case of HW failure the need to move to a low cost PC (for instance) may be needed with the exact same version that was installed on another architecture.
Another reason is this have already proved useful for others.
gizmocuz
Post by gizmocuz »
Domoticz stable versions now also make a backup, so there is no reason for this script correct?
lost
Post by lost »
gizmocuz wrote: Wednesday 17 January 2024 8:10 Domoticz stable versions now also make a backup, so there is no reason for this script correct?
Yes, that's less useful now. Could anyway help setting the exact same version that was running if domoticz host must be changed someday (HW failure...) for another model/arch (if my PI3B fails, for instance, I'll probably go to an Intel SBC as some are now a better bargain than raspberries+no Linux support issues like chinese ARM based alternatives), as well as issues screwing domoticz/storage with DBs/scripts otherwise saved but not the whole tree.
Egregius
Domoticz version: v2024.7
Post by Egregius »
Wouldn't it be better to first check if there's a newer version available?
This url will give you that info:
http://ip:port/json.htm?type=command&param=checkforupdate&forced=true
lost
Post by lost »
Egregius wrote: Wednesday 17 January 2024 8:58 Wouldn't it be better to first check if there's a newer version available?
Did not know about this url, looks that's also undocumented (only getversion is, but response now depends on who's logged/user setup so not easy to use).
Could be done, but this does not handle beta (but maybe there's another undocumented API for this) & if not used from the machine that hosts domoticz, will need it's IP... On top of parsing json from bash this may make the script a bit complex for the use-case IMO.
Kedi
Post by Kedi »
I have a somewhat smarter solution.
Change the updatebeta and/or updaterelease script from Domoticz to you liking.
And instead of the present
rm domoticz_beta.tgz
you could change that in
mv domoticz_beta.tgz <something else>
and save that on an other place.
This way you have a backup from the current dir and a tgz installation file of Domoticz of the new environment.
Latest and previous stables (to some extend) are present at github.
B.t.w. it might be that the contents of the dirs stable_240116 and stable_240117 might be the same.
lost
Post by lost »
Kedi wrote: Wednesday 17 January 2024 10:22 instead of the present
Yes, could be, but would only save current used system archive (so not keeping exact same version that may be installed on a new HW with different arch/os, if needed) & may cause issues to users unaware of the added feature in such automatic upgrade script with low storage: This would need further checks before proceeding & some auto-removal management as we're not in a user managed process there, supposed to know what he's doing... There's no install script provided to use these archives as well, so this targets users that are already confident with Linux CLI anyway.
