zigbeefordomoticz older version avalible?
Posted: Sunday 07 January 2024 22:19
by tjabas
since i run buster and domoticz version 2202.2 it seems impossible to install zigbeefordomoticz, i needs bullseye and a newer version of domoticz.
i have tried several updates to my system but i have alot of other software on the rpi that i get problems with if i update from buster.
is there any older versions of zigbeefordomoticz that can run on buster and domoticz 2022.2?
the maine reason that i want zigbeefordomoticz to work is that i have a sonoff 3.0 stick, and it doesnt seem that it can run on my 2022.2 version.
thanks in advance.
Re: zigbeefordomoticz older version avalible?
Posted: Sunday 07 January 2024 22:51
by pipiche
You can find all release here https://github.com/zigbeefordomoticz/Do ... e/releases
If you run buster, you can then go up to release [6.3.014](https://github.com/zigbeefordomoticz/Do ... -6.3.014-a)
You'll have to unzip or untar under plugins/Domoticz-Zigbee folder
Posted: Sunday 07 January 2024 23:00
by tjabas
Than you 👍😃
Posted: Monday 08 January 2024 21:15
by tjabas
Hi!
sorry but this might be a stupid question, but how do i install this older version, im used to just copy the links and paste them in putty/ssh, and do the installation that way,
do i need to install any other software then this zip that i have dowloaded?
when i have tried to install zigbeefordomoticz earlier times, there where other softwares that i needed to install in that guide.
do i need to install these ones also?
Posted: Monday 08 January 2024 21:31
by pipiche
So I guess there is an easier way
You can do as before, but after the git clone command you can simply do a git checkout stable6 to move to the stable6 version
git clone https://github.com/zigbeefordomoticz/Domoticz-Zigbee.git
Then you need to run the following command to get it initialized
git submodule update --init --recursive
git pull --recurse-submodules
From there you should be ok.
Posted: Monday 08 January 2024 21:51
by tjabas
Posted: Monday 08 January 2024 22:19
by tjabas
i think i managed to install it now, but do i have to delete the old zigate plugin? as for now i get both the old zigate settings menu and the new zigbee menu at once , even if i just choose the zigbee plugin , there both baked into one , if i delete the zigate plugin, do i then loose all my paired nodes?
i made a screenshot, i could get it all but i hope you understand what i mean.
Skärmbild 2024-01-08 222222.png (121.58 KiB) Viewed 9911 times
Posted: Tuesday 09 January 2024 9:25
by pipiche
Yes, you can have only one plugin code under the plugins folder. So you need to remove one and indeed you'll loose all.
Now I do not really understand what you try to achieve. If you have already one plugin installed and working why do you want to do?
Posted: Tuesday 09 January 2024 9:47
by tjabas
Im trying to get my sonoff 3.0 stick to work, now I have a zigate usb stick and I have problems with nodes randomly disconnect even if they are close to each other, I've had alot of problems with that, so that's why I want to move over to sonoff, I hope it will works better.
Posted: Tuesday 09 January 2024 9:58
by pipiche
Do not create a new plugin instance, Instead the best is to simply replace the Zigate by Sonoff. To do that: replace the Serial Port and the Coordinator model of Zigate by Sonoff
You'll make sure that you'll keep all devices.
Then you'll have simply to re-pair all devices with the Sonoff, and in such you'll keep the Domoticz widgets and all historical data
Posted: Tuesday 09 January 2024 10:07
by tjabas
Thank you for your help, do you think that the sonoff will work better then the zigate?
Posted: Tuesday 09 January 2024 10:29
by pipiche
oh yes, it is.
And more features like backup and restore of the key
For me zigate is a dead product, no update from the manufacturer, really a shame. And zigate is suffering from a closed/protected chipset from NXP
Posted: Tuesday 09 January 2024 20:31
by tjabas
thanks for your help, i have now installed the new zigbeefordomoticz and im up and running, i have a problem when im trying to include the nodes again, i get this in the error log, it seems like it can include the node because its already included, so i have deleted some of the old devices just to see if it can be included and it works, but i loose all the data and i need to reconfigure all the blockys and scripts.
do you have any easier way?
2024-01-09 20:26:43.077 Error: zigbee: processNotinDBDevices - Please cross check the consistency of the Domoticz and Plugin database.
2024-01-09 20:26:48.060 Error: zigbee: processNotinDBDevices - Devices already exist. Tv dimmer with {'Version': '3', 'ZDeviceName': '', 'Status': '8043', 'SQN': '02', 'Heartbeat': '5', 'RIA': '2', 'LQI': 147, 'Battery': {}, 'Model': 'TRADFRI bulb E27 CWS opal 600lm', 'ForceAckCommands': [], 'MacCapa': '8e', 'IEEE': '90fd9ffffeede7af', 'Type': '', 'ProfileID': 'c05e', 'ZDeviceID': '0200', 'App Version': '', 'Attributes List': {}, 'DeviceType': 'FFD', 'HW Version': '', 'Last Cmds': [], 'LogicalType': 'Router', 'Manufacturer': '117c', 'Manufacturer Name': 'IKEA of Sweden', 'NbEp': '1', 'PowerSource': 'Main', 'ReadAttributes': {'Ep': {'01': {'0000': {'TimeStamp': 1704828384, 'iSQN': {'0004': '00', '0005': '00'}, 'Attributes': {'0004': '00', '0005': '00'}, 'ZigateRequest': {}}}}}, 'ReceiveOnIdle': 'On', 'Stack Version': '', 'Stamp': {'time': 1704828389.7208202, 'Time': '2024-01-09 20:26:29', 'MsgType': '8011', 'LastSeen': 1704828389}, 'ZCL Version': '', 'Health': 'Live', 'Capability': ['Full-Function Device', 'Main Powered', 'Receiver during Idle', 'Standard security', 'NwkAddr should be allocated'], 'ZDPSQN': '03', 'PairingInProgress': True, 'Epv2': {'01': {'ClusterIn': {'0000': {}, '0003': {}, '0004': {}, '0005': {}, '0006': {}, '0008': {}, '0300': {}, '0b05': {}, '1000': {}}, 'ClusterOut': {'0005': {}, '0019': {}, '0020': {}, '1000': {}}, 'ProfileID': 'c05e', 'ZDeviceID': '0200'}}, 'ZCLSQN': '00', 'RollingLQI': [147, 147], 'Param': {'PowerOnAfterOffOn': 255, 'fadingOff': 0, 'moveToHueSatu': 0, 'moveToColourTemp': 0, 'moveToColourRGB': 0, 'moveToLevel': 0}, 'ConfigSource': 'DeviceConf', 'Ep': {'01': {'0000': {'0004': 'IKEA of Sweden', '0005': 'TRADFRI bulb E27 CWS opal 600lm'}, '0003': {}, '0004': {}, '0005': {}, '0006': {}, '0008': {}, '0300': {}, '0b05': {}, '0019': {}, '1000': {}, 'Type': 'ColorControlRGB'}}, 'ZDeviceVersion': '0000', '_rawNodeDescriptor': '117c005200520000008e524001', 'Max Buffer Size': '52', 'Max Rx': '0052', 'Max Tx': '0052', 'macapa': '8e', 'bitfield': '4001', 'server_mask': '0000', 'descriptor_capability': '00'}
Posted: Wednesday 10 January 2024 22:03
by tjabas
im finally up and running, im including all the nodes again, not so painful as i thought, thanks pipiche for your help.
but im getting an error message all the time both in the zigbee and domoticz log:
142: Object {"Time":"10/01/2024 21:52:24","Module":"DZDB","nwkid":"None","PluginHealth":"Ready","message":"Urlopen to 127.0.0.1:8080/json.htm?type=devices&rid=6227 rejec
any idea what this means?
