ZigbeeForDomoticz
Posted: Saturday 06 January 2024 17:49
by iw2fag
I have a question.
I manage three Home Automation devices based on Rpi3B+ which have the same Hw configuration which obviously control different devices :
[Rpi3B+] [2,2" Status display] [PIiJuice] [Texas Instrument Znp] closed in a 35mm DIN module with fan.
I use BullsEye + Domoicz + Zigate + DGTBoot (Telegram remore Control).
Recently in order to use the latest releases of Zigate I had to upgrade to BullsEye and it had already been complicated to remember everything needed.
So I made myself a disk image where to type different information between the three domotic contoller I save the dB of domoticz, a settings file to direct the telegramm bot, some telegram menu management file that differs between the three applications.
For now I have not yet found a way to "export" and import the configuration of the ZigBee plugin in an easy way as it is given with the Domoticz DB.
I basically copy the whole installation folder.
What ZigBee files should I save for each individual implementation where they are, so that I can BackUp for a possible restore ?
ps. As of today 6 January 2024 BookWorm 32 bit on RPi3 is not manageable by VNC and therefore I am not upgrading to that system, the 64bit version of the same OS does not enjoy adequate sockets to manage the telegramm bot.
Thank you Andrea.
Re: ZigbeeForDomoticz
Posted: Saturday 06 January 2024 18:16
by pipiche
iw2fag wrote: Saturday 06 January 2024 17:49
Thank you Andrea.
https://zigbeefordomoticz.github.io/wik ... ackup.html
Posted: Saturday 06 January 2024 18:30
by solarboy
I love that fusebox display !
Posted: Sunday 07 January 2024 9:41
by Thorgal789
Hello, what are you using for the 2,2" Status display ?
Posted: Sunday 07 January 2024 10:22
by iw2fag
Thorgal789 wrote: Sunday 07 January 2024 9:41 Hello, what are you using for the 2,2" Status display ?
I have a script in python that manages the monitor by accessing system information, captures data from domoticz, checks that the battery is never more than 80% charged.
I check a few parameters.
The monitor is connected via Spi on the GPIOs.
There was a usage trace in adafruit com that I no longer see.
If you are interested I can attach what I had retrieved some time ago.
Posted: Sunday 07 January 2024 10:23
by iw2fag
pipiche wrote: Saturday 06 January 2024 18:16
Thank you Andrea.
Thanks for this great job.
I'll do a donation once a year.
Posted: Sunday 07 January 2024 16:55
by Thorgal789
Woaw, seriously, now I m seing the hardware inside, I see better the work you have done.
Realy impressive, and it's realy "professionnal" result
