MQTT and Zwave-JS-UI problems connection to Domoticz
Posted: Thursday 04 January 2024 2:55
I got an unwanted surprise when the support for OpenZwave disappeared in the new Domoticz release.
Therefore, I had to follow the instructions on how to setup zwave2mqtt and so far all the devices are visible in ZWaveJS-UI and parameters in Domoticz hardware settings are corresponding to the settings there.
I also installed the MQTT broker.
However, no devices are coming into and are visible in Domoticz hardware settings.
I suspect that Domoticz cannot pick up the devices as it should, I suppose.
Does anyone knows how to come further?
I'm running Domoticz directly on a Ubuntu Linux and have installed the MQTT broker. ZWaveJS-UI is running in Docker on the same machine. I have posted the logs from ZWaveJS-UI if this may help.
My mosquitto conf file has
listener 1883
allow_anonymous true
listener 1883
