Unable to setup domoticz
xavierlp
Post by xavierlp »
Hello
I am using a fresh version on the last version of raspbian of RPI4
When I run
curl -sSL install.domoticz.com | sudo bash
::: You are root.
::: Verifying free disk space...
::: apt-get update has not been run today. Running now... done!
::: Checking apt-get for upgraded packages.... done!
::: Your system is up to date! Continuing with Domoticz installation...
:::    Checking for apt-utils... installed!
:::    Checking for whiptail... installed!
:::    Checking for git...pi@raspberrypi:~ $
Is it known ?
Do you know a workaround ?
Thanks a lot
xavierlp
Re: Unable to setup domoticz
Post by xavierlp »
need to install git ...
Solved
Users browsing this forum: binbo and 1 guest
