"DIMMER" level inaccessible
progresive
Post by progresive »
DIMMER type switch in domoticz.
Version: 2023 .2
Build Hash: 19efd039c
So far, I have get the slider level in LUA with the command:
volume = devicechanged[glosnosc]:gsub('%D', '')
because the command devicechanged[volume] returned:
LUA: Set Level: 63 %
probably after the last Domoticz update, when changing the level using the slider, it returns only On. There is no information about the level/position:
 Status: LUA: On
How to get the state of DIMMER in LUA ?
Re: "DIMMER" level inaccessible
I don't know the answer as I don't use the basic Lua integration. In Dzvents it works without issues.
So if nobody will answer this you could consider to switch/convert your Lua script to dzvents (based on Lua and much better documented)
