Extended Python Framework Options parameter
pipiche
Post by pipiche »
In the Domoticz Python Framework, the Options parameters is documented as Read/Write, however when
Doing
Devices[DeviceID_].Units[Unit_].Options = Options
This trigger an exception
AttributeError: readonly attribute
For exemple when using a Electricity (instant and counter), if we detect that the Energy is provided by the hardware, we want to set options with
{'EnergyMeterMode': '1'}
Zigbee for Domoticz plugin / RPI3B+ / Electrolama ZZH-P / 45 devices
If the plugin provides you value, you can support me with a donation Paypal.
Wiki is available here.
Zigbee for Domoticz FAQ
JanJaap
Domoticz version: Dev
Re: Extended Python Framework Options parameter
Post by JanJaap »
You would normally provide the options during the creation of the unit. Does that not work for you or do you need to modify it after creation?
The documentation indeed suggests you can update it after creation, so either documentation or implementation would need updating ;)
Domoticz version: 2024.7
pipiche
Post by pipiche »
JanJaap wrote: Wednesday 20 December 2023 19:20 You would normally provide the options during the creation of the unit. Does that not work for you or do you need to modify it after creation?
Yes and no, because in Zigbee the plugin that we have discover the Device functionality. And during the discovery, the device can expose the Metering functionality, however it is only after a short while that we will get or not the summation .
This is why we create the Device at the discovery time set by default 'Computer' and as soon as we receive a summation we update the Options
